1970 fan shroud screws #1093874
10/13/11 07:50 PM
10/13/11 07:50 PM
BLACKHEMIRR Offline OP
Does anyone know what type the original screws were that hold the shroud on a 70 6 pack radiator (2998956)? I think they were hex head with captured washers, but I'm not sure. There are 2 screw clips still on my radiator, one that takes a course thread sheet metal screw, and one that takes a fine thread screw. I guess one of them might be correct. If you have any extras, I'll take'em!
Re: 1970 fan shroud screws [Re: BLACKHEMIRR] #1093875
10/13/11 11:09 PM
10/13/11 11:09 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
They are the fine threaded ones with hex head and large(compared to the size of the hex head) captive washer. Early ones had SEMS stamped into the hex head, all later ones have a stylized P stamped into them. You will need four of them and four of those small clips. I might have a few extras. Do you need a picture posted?
Re: 1970 fan shroud screws [Re: BLACKHEMIRR] #1093876
10/13/11 11:23 PM
10/13/11 11:23 PM
WV
Little Detroit Offline
WV
We carry them and have them in stock.
Re: 1970 fan shroud screws [Re: Little Detroit] #1093877
10/14/11 07:36 AM
10/14/11 07:36 AM
Thanks for the help.
Re: 1970 fan shroud screws [Re: BLACKHEMIRR] #1093878
10/14/11 09:20 AM
10/14/11 09:20 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
They are an 8-32 x 3/4" sems screw - 5/16" Hex head with 5/8" Conical washer, clear zinc , "P", head marking.
Re: 1970 fan shroud screws [Re: gtx6970] #1093879
10/17/11 07:42 PM
10/17/11 07:42 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
