Best way to block off intake ports for cleaning head?
#1093779
10/13/11 04:10 PM
10/13/11 04:10 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I'm replacing my intake manifold gaskets and cleaning out the crossover on my 318. I just finished cleaning the intake gasket surfaces with a scraper and a wire wheel (which is a wonderful new tool to me, I come from working on all-aluminum stuff you can score up with a cheap screwdriver).
Usually I just plug ports with some paper towels, but I'm used to working on upright inline engines, not V engines where the ports are at an angle and consequently stuff can fall down inside pretty easy. I have the rockers and valley sealed off with masking tape and saran wrap. What works well to block off the intake ports but still allow cleaning AROUND the intake ports? It seems like using paper towels could potentially let debris slide past when I pull them out, even if I vacuum when I'm done.
I know this is probably a dumb question, but if there's a better way than layering masking tape over the port and then xacto-knifing around it, it'd save me a lot of time.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Best way to block off intake ports for cleaning head?
[Re: Secret Chimp]
#1093781
10/13/11 05:40 PM
10/13/11 05:40 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
get some foam rubber, cut into chunks, and insert into ports/bores.
[Re: Golden-Arm]
#1093782
10/13/11 06:47 PM
10/13/11 06:47 PM
Posts: 15,487 Florida
scratchnfotraction
i have my son work the shop vac holding it right at the scraper or wire wheel I prefer the rol loc scothbrite pads for cleaning the gasket surfaces I have also bald up tape and work the sticky side out,then stuff it into the ports,this will let stuff stick to the tape and come out when removed. wipe it all down with brake clean on a rag(so you dont get any in the oil) then install gaskets/intake.
[Re: scratchnfotraction]
#1093783
10/13/11 07:38 PM
10/13/11 07:38 PM
RapidRobert
good suggestions & I'd definitely stay aware (& you are) that the wheel is going to sling it everywhere far and wide
[Re: JohnRR]
#1093787
10/14/11 12:03 PM
10/14/11 12:03 PM
Posts: 1,322 Michigan
crlush
I have always found a single edge razor blade to work well removing gaskets and keeping the mess, and damage to gasket surfaces , to a minimum.
