TRANS GURU'S HELP !!! #1093775
10/13/11 03:39 PM
10/13/11 03:39 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Made 2 passes last night ,,trans didn't shift right. t- flight..second pass launched great but didn't go into 2 nd kinda slid thru into 3 rd...as I got off the track it wouldn't move at all..no forward and no reverse..Hauled it home and today I just fired it up and drove it into the garage..DUH !!! Last night it wouldn't move and today I drove it .. Whats that all about.??? Yes the fluid is full and not burnt..any ideas ???
Re: TRANS GURU'S HELP !!! [Re: dynamite] #1093776
10/13/11 04:32 PM
10/13/11 04:32 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Adjust your bands.
The front one would be the offender here.
I've had this issue before where it wouldnt shift until I slightly let off then it would go right into third. It was because my band was Worn and too lose to hold the drum. might not be your problem but worth trying the adjustment.
Re: TRANS GURU'S HELP !!! [Re: dynamite] #1093777
10/13/11 05:17 PM
10/13/11 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A loose kickdown band could account for the lazy 1-2 shift but bands aren't involved in moving the car forward from a standstill...sounds like a pressure problem when the fluid is hot.
Re: TRANS GURU'S HELP !!! [Re: John_Kunkel] #1093778
10/13/11 06:38 PM
10/13/11 06:38 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Thanks guys for your help...John, I sent you a PM check it out,need some help here ,,wish I knew you when I needed annuals on my Bonanza.
