Re: NEXT QUESTION................................
[Re: Cab_Burge]
#1093713
10/13/11 05:57 PM
10/13/11 05:57 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
hughes has a 2 piece plate i have been looking at - BUT - it doesnt have a drop out centre,it splits in 2. they did say it works with eddy and stealth heads when i rang them http://www.hughesengines.com/Index/produ...mp;partid=24085does look a little agricultural Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1093715
10/14/11 12:02 AM
10/14/11 12:02 AM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
Tex
I used one with Eddie heads, never had a problem with it, didnt leak a bit, it comes with sheet metal screws to put the halves together, I used aircraft nut plates and a small bead of sealer between the havles, I would use one again on another BB build.
[Re: PS Arrow]
#1093717
10/14/11 01:40 AM
10/14/11 01:40 AM
tex013
Sydney,Australia
PS thanks for the real world reply
Tex
[Re: rickraw]
#1093719
10/14/11 07:24 AM
10/14/11 07:24 AM
Posts: 4,075 Mo.
racerx
Mo.
i have a sb with w9"s. i got a plate from the scrap yard & made my own. it's easy & cheap. stay safe, seeya.
Any pic's
[Re: racerx]
#1093720
10/14/11 10:17 AM
10/14/11 10:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Any pic's
I built one for my SB W-9 also... 1/4 billet ... I'll see if I took a pic of it
[Re: MR_P_BODY]
#1093721
10/14/11 02:34 PM
10/14/11 02:34 PM
Posts: 4,075 Mo.
racerx
Mo.
Any pic's
Thax.Mr.P look at the ones on line they r kind of pricey looking at my options,has anyone converted there present one into one with a removable top?
[Re: Thumperdart]
#1093722
10/14/11 08:30 PM
10/14/11 08:30 PM
BradH
Why would the gap be different on the rpm heads?
Because the Performer RPM heads don't have an extended intake runner like the Indy heads do which creates a little overhang for their (Indy's) cover to slide under.
Regardless, I know at least one person (labratt?) used the Indy cover w/ Performer RPM heads and ended up RTV-ing the he11 outta it to seal it up.
[Re: racerx]
#1093724
10/14/11 09:05 PM
10/14/11 09:05 PM
MR_P_BODY
Any pic's
This was what I made for my W-9... I had a sheet metal (alum) but it leaked a little and I didnt like that
