SB STD stroke RHS headed combos - how fast have u gone? #1093580
10/13/11 02:53 AM
10/13/11 02:53 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Looking to do a buget upgrade on an otherwise healthy 360 bottom end.
Already have 1.5 rollers and 1 3/4" headers in an A body and wondering how fast you SB guys have gone with similar pump gas, RHS headed stock stroke 360 combos?
Let's hear em thanx !!!!
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: LAD 524] #1093581
10/13/11 03:02 AM
10/13/11 03:02 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Waiting for Brian from IMM to chime in.
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: moparpollack] #1093582
10/13/11 07:28 AM
10/13/11 07:28 AM
Guitar Jones Offline
Didn't Brian run 10.90's with one in his Duster?
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: Guitar Jones] #1093583
10/13/11 08:34 AM
10/13/11 08:34 AM
The Great White North
RAMM Offline
RAMM  Offline
I believe Brian ran those numbers with W2's. J.Rob
p.s. I don't know what it would run but I just ran an EQ headed 3.58" stroke 360 at the EMC and made 515hp 495 ft/lbs. Here's the link
360 dyno pull @ EMC2011
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: RAMM] #1093584
10/13/11 11:59 AM
10/13/11 11:59 AM
SoCal
Brian Hafliger Offline
SoCal
When I ran our CC engine in my car it clicked off a 6.94 run which in theory would be close to a 10.90-11.00 1/4 mile run. It went 96mph in the 1/8.
Here's a vid:
http://imageshack.us/clip/my-videos/192/irwindalevids002.mp4/
Brian Hafliger
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: Brian Hafliger] #1093585
10/13/11 12:05 PM
10/13/11 12:05 PM
SoCal
SoCal
Another vid:
http://imageshack.us/clip/my-videos/13/irwindalevids003.mp4/
I ran it with mufflers, a 10" Hughes converter (borrowed from Rob), the larger headers that made less power on our dyno (all that would fit my car), mech. water pump, alternator, just like it was a street car but with slicks and foot brakin'!
This was just like I dyno'd it, 750DP and all.
Brian Hafliger
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: Brian Hafliger] #1093586
10/13/11 12:23 PM
10/13/11 12:23 PM
sweden
sshemi Offline
sshemi  Offline
sweden
this wasnt std stroke was it?
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: sshemi] #1093587
10/13/11 01:38 PM
10/13/11 01:38 PM
SoCal
SoCal
No, I was just posting up what I did since it was in question. I don't have much feedback from smaller engines using our RHS heads, but one customer in Denver said he went 13.00's with a street dart, 360, our heads, 285HL cam, 10.5:1 compression, 750DP, rpm air gap, 4.10 gear and 727.
Not too bad...
Brian Hafliger
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: Brian Hafliger] #1093588
10/13/11 05:58 PM
10/13/11 05:58 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Mine is in my sig
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: mshred] #1093589
10/13/11 06:34 PM
10/13/11 06:34 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx for the input fellas....seems that there's so much focus on strokers these days.
Would really love to know what a tight quench, pump gas 360 with a nicely prepped set of RHS heads should do in an A body.
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: LAD 524] #1093590
10/13/11 06:37 PM
10/13/11 06:37 PM
Toronto
mshred Offline
mshred  Offline
Toronto
well just to give you some perspective...my motor was a junkyard shortblock, had measly compression, with just Brians RHS heads and his custom grind cam and my car ran like a bat outta H#$%!
So just imagine what a compression bump would do with the same mild parts...i think high 11's or faster are easy, and thats in a heavy car like mine
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: mshred] #1093591
10/13/11 06:47 PM
10/13/11 06:47 PM
Fort Collins, Colorado
CoDart Offline
CoDart  Offline
I'm in high altitude Colorado and have a 360 magnum with rhs heads, .225/.525 lift, air gap, 750dp, 9.5 compression, hedman headers, 3.91 gears, 3500 stall and a 3480lb car with 275/55/15 drag radials. Have gone best of 13.7@98mph. Has more in it, with tuning and traction it should be 13.5s. That time was with 8600 DA.
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: mshred] #1093592
10/14/11 03:52 AM
10/14/11 03:52 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I think you need to tell the whole story.
I got very interessted.
Please tell about the 4 speed also.
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: sshemi] #1093593
10/14/11 05:05 PM
10/14/11 05:05 PM
Toronto
mshred Offline
mshred  Offline
Toronto
sure, i'd be glad to share man...combo is very basic
3400lb car with me in it- thats all steel, full interior, with a full sound system as well (on the wheels up runs my subwoofer would launch to the back of the trunk- had to fix that lol)...using a 2.66 first gear 4 speed, centerforce clutch, leaving at 5k, shifting at 6k (my foot never comes off the gas), crossing the stripe at 5500rpm. It has a 4.10 dana 60 in it (needs more gear, but i drive it to the track 2 hours buzzing 3k the whole way there and back)...I run the full caltrac setup front and back minus their monos, and i use a 28x12.5 et street bias ply tire (like about 12 psi)
Engine is a 91 360LA factory roller block
BONE stock bottom end parts...I had to flycut the factory (already dished) cast pistons on the intake side. Rods have new rod bolts..no balance job...just a ball hone, new rings and bearings
Cam is a custom ground hydraulic roller from IMM
Heads are RHS from Brian at IMM as well..62cc chambers, with a composite thin head gasket, I have a calculated 8.5-8.8:1 compression (depending on calculator you use)
Eddy Air gap intake, 750HP holley, 1-5/8 headers 3" exhaust with x pipe and borla race muffs
I run 36 degrees all in by 2300rpms...this thing drinks back 87 octane, doesnt ping at all, and runs like a scalded dog ...Brian at IMM was a huge help, and I can tell you, everything he predicted about this motor power wise and all was spot on...he definitely knows his stuff, is super nice, and super reasonable too..can't thank him enough
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: mshred] #1093594
10/14/11 05:27 PM
10/14/11 05:27 PM
owt west
Thread Ender1 Offline
owt west
Here's mine very very basic, 410ci Rhs small hyd roller thru flowmasters on drag radial. still undialed do to inconsistant traction due to all the Honda's oiling the track every time i go out. http://youtu.be/rewKjJpqGRs
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: Thread Ender1] #1093595
10/14/11 05:45 PM
10/14/11 05:45 PM
My stock stroke 340 banged out 12.40's with 9 bent valves, 13 bent pushrods and 12 broken valve springs with old J heads. Can the RHS's do better? I would think so.
BTW I bought it that way.
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: Guitar Jones] #1093596
10/25/11 02:16 AM
10/25/11 02:16 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Keep em coming fellas....
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: LAD 524] #1093597
12/05/11 11:15 PM
12/05/11 11:15 PM
Toronto
mshred Offline
mshred  Offline
Toronto
thought I would bump this back up as it seems interesting
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: RAMM] #1093598
12/05/11 11:16 PM
12/05/11 11:16 PM
Toronto
mshred Offline
mshred  Offline
Toronto
is there a link to a build thread on here of that engine or a run down what parts were in it?
Re: SB STD stroke RHS headed combos - how fast have u gone? [Re: mshred] #1093599
12/06/11 12:04 AM
12/06/11 12:04 AM
CoDart Offline
CoDart  Offline
My engine combo is very similar to MSHREDS. I have a 360 with 9.5 compression, 0.525 lift/0.227 duration cam, Forged pistons, MLS head gaskets, RHS heads w/ stainless valves from hughes, air gap intake, 750 DP, 1-5/8 headers and 2 1/4 exhaust with flow 40's.
I run it on 85 octane fuel and it seems to very happy.
The car weights 3480 with me(210lb) and it has a 3000 PTC stall with a low gear set 904 and a 8 1/4 rear with 3.91 gears.
Rear suspension is all stock just the leafs are moved into the frame rails. Rear tires are 275/50/15 ET street radials. Have gotten a highest reading of 14mpg to, not to shabby.
I launch at about 1400rpm and keep it in Drive, it shifts on its own at about 5800rpm.
Quickest I have been is 13.78@98mph. Keep in mind that was at 8400 D/A. Up in high altitude country the cars seem like they are breathing through little straws. My car has beat new srt8 challengers, modded 440 challengers, 383 roadrunners, new camaro ss. Not to brag but these RHS headed 360's in lightweight cars can really hold their own.
