Pump gas friendly race motor #1093478
10/12/11 09:51 PM
10/12/11 09:51 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
How much squeeze? It will be 572 cubes, figure an optimized cam for dealing with pump gas, will be a roller. Will see a shot of spray at the track with some better gas. Will see street time, must not be temperamental. What sort of compression should I shoot for... ballpark, I know it's a loaded question. I'm thinking 11:1 ish? Alum. heads and block.
I have a few ideas rolling around in my head, have to see how things pan out over the winter. Looking for opinions of people who know pump gas stuff. Not looking to push the ragged edge. I figure if I can make 750ish HP I can easily spay it to 8.50's and run 9.20's on motor, plenty fast enough to go get ice cream. And maybe start having fun with the car again at the same time...
Re: Pump gas friendly race motor [Re: Bigcube] #1093479
10/12/11 10:05 PM
10/12/11 10:05 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i'm at 12-1 with 185 cranking comp. that comp increase came from the indy heads. with rpm heads i was at 10.5-1 with 185 cranking comp.
credit goes to Dan @ Performance Only for specing the cam. it is more tame than the 590 mopar shaft i had before
Re: Pump gas friendly race motor [Re: sixpackgut] #1093480
10/12/11 10:24 PM
10/12/11 10:24 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
Wow! 12:1? I guess it's all about the cam. I can see bleeding off cranking compression, but no ping under load? I never thought you could be safe at 12:1 with pump swill.... guess I have a lot to learn!
Re: Pump gas friendly race motor [Re: Bigcube] #1093481
10/12/11 10:28 PM
10/12/11 10:28 PM
Delray beach, Florida
P
Performance Only Offline
P
Jim, send it down here. 750 HP on pump gas won't be a problem. it is more than just a cam change to do it right though.
Ray, yours sounds tamer than the 590 MP cam until you push the pedal on the right.
machine shop owner and engine builder
Re: Pump gas friendly race motor [Re: Bigcube] #1093482
10/12/11 10:30 PM
10/12/11 10:30 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
That's good news Jim. If you want to make the trip back to Norwalk for some icecream at next season I'll buy.
Butch
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Pump gas friendly race motor [Re: Bigcube] #1093483
10/12/11 10:32 PM
10/12/11 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It ALL comes down to the dynamic compression... my
14.1:1 has 185 cranking pressure
Re: Pump gas friendly race motor [Re: MR_P_BODY] #1093484
10/12/11 10:39 PM
10/12/11 10:39 PM
P
P
but what does that cylinder pressure become at 3000 rpm? cars don't tool around the streets on cranking compression.
Re: Pump gas friendly race motor [Re: Performance Only] #1093485
10/12/11 10:47 PM
10/12/11 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have no way to measure that
Re: Pump gas friendly race motor [Re: Bigcube] #1093486
10/13/11 12:14 AM
10/13/11 12:14 AM
My 518 low deck motor with 440-1 CNC ported by MCH made 775 HP on Oregon pump gas with 10.8 to 1 compression and absolutely no quench to speak of.(at 4300 FT above sea level also, DTS dyno straight up no fudging ) The pistons have a 22 CC dish because the motor originally had a set of ported 906 iron heads on it I should replace the pistons to a set of reverse dome with some quench, I'm sure there is some power there It is way easir to turn up the squeeze HP than it is to start with to much compression Big motors(C.I.) make a lot of power without a bunch of compression I'd shoot for 10.5 to 1 or lower
Re: Pump gas friendly race motor [Re: Bigcube] #1093487
10/13/11 12:23 PM
10/13/11 12:23 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Jim, you know hemis are different than wedges, but I have about 11:1 in my hemi and it runs fine on pump 93...when I get the non ethanol stuff. It has 185 psi cranking. Summer time w/ ethanol blended 93 it will rattle and lose a noticeable amount of power.
My 440 is 14.5:1 and has 185 psi cranking compression also, but it'll never see anything but race fuel.
The pump 93 isn't what it was a few years ago, so I'd go conservative on the compression if it was me.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pump gas friendly race motor [Re: an8sec70cuda] #1093488
10/13/11 03:48 PM
10/13/11 03:48 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have not had my hemi togather and running on the new ethanol based crap, but it is 11.6:1 and was not an issue on 92 octane. I think the big chambers expand a little when up to temp though. It might be 11.6:1 at room temp, but I am sure its not 167cc chambers at 180*...
Re: Pump gas friendly race motor [Re: Dragula] #1093489
10/13/11 05:46 PM
10/13/11 05:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am at 10.6 with the aluminum heads. Have not checked cranking comp but I can tell you I have no ping at all and the total is at 37. The timing is all in by 2000 and the eng has good quench. Ron
Re: Pump gas friendly race motor [Re: 383man] #1093490
10/13/11 07:01 PM
10/13/11 07:01 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
Thanks everyone for the responses. Seems like 10.5-11.5ish compression with the correct cam should be fine. What do people do to pick a cam and have cranking compression end up where it needs to be? Is that adding more duration? Or overlap? Just curious what would be different in a pump gas cam compared to a high compression/race fuel cam? I would leave spec'ing the cam to the professionals, more just curious ow they would be different.
Re: Pump gas friendly race motor [Re: Bigcube] #1093491
10/13/11 11:05 PM
10/13/11 11:05 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
11.89 to 1
162 low 170 high cranking compression Races on junk 93 BaBy
Mopar Performance
Re: Pump gas friendly race motor [Re: Bigcube] #1093492
10/14/11 09:10 AM
10/14/11 09:10 AM
Dwayne spec'd the cams in both of my motors. The 440's cam is a more radical profile...pretty much race only. Yet you see the compression difference.
My little 440 makes my Hemi sound like a 383, lol.
CHIP
Re: Pump gas friendly race motor [Re: Bigcube] #1093493
10/14/11 10:46 AM
10/14/11 10:46 AM
Colo
P
PJ68RT Offline
PJ68RT  Offline
P
Colo
Later intake closing...shortens the effective stroke giving less compression pressure.
http://www.wallaceracing.com/dynamic-cr.php
Re: Pump gas friendly race motor [Re: PJ68RT] #1093494
10/14/11 11:21 AM
10/14/11 11:21 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
That's what I like. Mine is 73! Dynamic compression is more important overall .... IMO... at altitude that program has me' at 165 and like I said 11.89 to 1 and my low is 162 and high 170. ...
Mopar Performance
Re: Pump gas friendly race motor [Re: PJ68RT] #1093495
10/14/11 03:25 PM
10/14/11 03:25 PM
P
P
that's only one part of the puzzle though when you need to make good power too. other things need to be done with the cam depending on the power needed. just moving the closing point isn't the answer.
Re: Pump gas friendly race motor [Re: Performance Only] #1093496
10/14/11 04:51 PM
10/14/11 04:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
From the looks of things, 185 PSI of cranking pressure seems to be the target # for pump gas - right ???
Re: Pump gas friendly race motor [Re: Stanton] #1093497
10/14/11 06:35 PM
10/14/11 06:35 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
Here's what that page spits out for my current compression/cam
Your dynamic compression ratio is 11.21:1 .
Your dynamic cranking pressure is 244.55 PSI.
So it's safe to assume this WON'T run on pump gas
