Re: high nickel content blocks??
[Re: Supercuda]
#1093369
10/13/11 08:50 AM
10/13/11 08:50 AM
Posts: 5,337 the house on the left.
cogen80
Is there any truth about these blocks and the years ? Where can you find info ? 440 / 360
Quit reading Car Craft/Hot Rod
hell the high nickel block thing was printed in one of the mopar magazines many years ago.
[Re: ahy]
#1093372
10/13/11 02:40 PM
10/13/11 02:40 PM
Posts: 4,255 Canada
WO23Coronet
Canada
If there was any change in metalurgy, it doesn't seem to have much functional or practical impact. As indicated in the 440 source writeup and a MA article written about the same time, the later blocks are in many respects better for a hi po build. In practice they do fine up to the limits of any stock block.
The most important thing seems to be to check cylinder wall thickness if you are making lots of power and/or pushing the overbore. That varies quite a bit from block to block and hole to hole.
I think the MA article concluded that the later blocks were thicker and heavier that the earlier ones, but the cast iron used was a tad bit softer.
Since we're talking about high nickel blocks, were the 426 Hemi's high nickel content? What about the industrial blocks (413, 426 etc)?
[Re: runner12]
#1093373
10/13/11 05:26 PM
10/13/11 05:26 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There were high-nickel blocks made but they didn't show up in any production car.
[Re: John_Kunkel]
#1093374
10/13/11 07:32 PM
10/13/11 07:32 PM
RapidRobert
There's a place where you can send a chunk of metal (ore) to be assayed for content. Wouldn't be difficult to send em 2 different minute chunks from 2 different blocks to be analyzed. No idea on the cost or even the company name but it could be found if a person wanted to get serious about this
[Re: RapidRobert]
#1093375
10/13/11 08:50 PM
10/13/11 08:50 PM
Posts: 10,736 North Dakota
6PakBee
North Dakota
A quick trip though AN FSM shows a number of statements about high chrome alloy cast being used for heads. The old DC performance book refers to the 'X' block as being a 'hi-tin content' block. Can't find anything on high nickel.
[Re: John_Kunkel]
#1093377
10/14/11 12:07 AM
10/14/11 12:07 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
The 426 wege NASCAR blocks where suppose to be high nickle content and I heard, not from a Mopar employee, that some of the Chrysler marine blocks, all sizes, not just B & RB blocks where high nickel also BTW, as far as the X designation on castings from Mopar I was told by Larry Shepard or Tom Hoover(at one of the drag seminars back in the late 1970s) that the X desgination indicated heat treat on those castings
[Re: Cab_Burge]
#1093378
10/14/11 12:13 AM
10/14/11 12:13 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
MA tested and found there to be higher nickel in the earlier blocks, but the later blocks were thicker, as many have stated. That may not satisfy some, but that was the reporting.
I want my fair share
[Re: SomeCarGuy]
#1093379
10/14/11 12:23 PM
10/14/11 12:23 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
The bottom line is that earlier blocks being better is another famous Mopar urban myth. There is ZERO reason not to use a later block and in many cases it's a better choice due to improvements in the castings and less core shift.......Check the block and use it if it's good; the year is irrelevant.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1093380
10/14/11 12:41 PM
10/14/11 12:41 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Please stop that crazy talk ...
[Re: JohnRR]
#1093382
10/14/11 04:02 PM
10/14/11 04:02 PM
DPelletier
Yeah, I know..... There should be an Urban Myth section in the Archives where we could put some of this stuff and then we could just link it instead of typing...... Let's see, we could start out with the following; - HP2/6 Pack Blocks - "6 Pack" rods - 906 "440 Magnum Heads" - thick/thinwall castings - one of my personal favorites; '70 Coronet grills came from the Edsel! - All 6 pack cars got torque boxes - All 6 pack cars got 26" rads - a 383 is significantly lighter than a 440 .....there has to be dozens more, though some would be a little "controversial" And of course, we need the sign; Dave
1974 'Cuda
