My Engine Is Finally Ready
#1093269
10/12/11 02:41 PM
10/12/11 02:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Today I primed the oil system and checked it all over for oiling to the rockers... this engine (416 ci) uses PR oiling... all that looked good... no leaks in my pan that I made... the oil system now is a 9 qt system.... so now its time to put the engine in the Rampage and build the headers.... I'm pretty happy today
Re: My Engine Is Finally Ready
[Re: mafo]
#1093277
10/12/11 04:17 PM
10/12/11 04:17 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Looks great let me know when your finished up Mr-P and we...you can get started on my headers i'll buy the beer and pizza! LOL make sure you take some pics when you start on the headers, i need all the help i can get!
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: mafo]
#1093279
10/12/11 04:26 PM
10/12/11 04:26 PM
MR_P_BODY
looks serious
Not really... should be in the 525-550 hp range... pump gas, 10.53 compression, W-5 heads w/2.08 intake valves, ported w/310 cfm at .650, cam is a 260/262 640/640 with a 105 LSA in at 105, TD rockers, M1 intake... right now it has a 850 on top but I do have a 1050... I only want the Rampage to run 10.1 - 10.2 ... this is my street rod/drag week car.... this engine is pretty much built from parts I had laying around the shop other than the pistons
[Re: MR_P_BODY]
#1093280
10/12/11 05:29 PM
10/12/11 05:29 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Looks good Mike, and that sounds like a perfect street strip mill.
[Re: MR_P_BODY]
#1093282
10/12/11 05:35 PM
10/12/11 05:35 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
Looks good. What do you expect the Rampage to weigh in at?
[Re: ProSport]
#1093283
10/12/11 05:37 PM
10/12/11 05:37 PM
MR_P_BODY
Thanks guys... I'll see how it turns out after I make a couple of passes and how it acts on the street... I think it should be fine... with that 105 cam it should have a lot of thump to it.... it might sound fast..... even if it isnt
[Re: Guitar Jones]
#1093285
10/12/11 06:22 PM
10/12/11 06:22 PM
MR_P_BODY
I figure it to weigh in with me at 2800#... plus or minus a little
[Re: MR_P_BODY]
#1093287
10/13/11 07:22 AM
10/13/11 07:22 AM
Guitar Jones
You may have to slow it down to get that 10.1-10.2 time slip.
