340 Water Pump #1092897
10/11/11 09:14 PM
10/11/11 09:14 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
Should the 340/a/c have 6 or 8 blades on the impeller? The one I took off has 6 but it's red and I can't be sure it's original on my 69? The replacement one has 8 blades. I know on big blocks, maximum cooling systems have 6 blades. It's something to do with moving the coolant slower it faster to get the optimum rate of flow. I was going to use a Flowkooler pump but the a/c bracket will not clear the extra bulge on the top of the pump for the optional location for a mechanical sending unit
Re: 340 Water Pump [Re: RoadRunnerJD] #1092898
10/11/11 09:54 PM
10/11/11 09:54 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If your not concerened about originality, and have some extra $$$, buy the edelbrock water pump. The vanes have significantly more surface area than any of the oem style pumps.
Re: 340 Water Pump [Re: Neil] #1092899
10/11/11 10:57 PM
10/11/11 10:57 PM
Warrenton, VA
Warrenton, VA
I already got a stock replacement but I'm worried it's not good enough because it has 8 blades?
Re: 340 Water Pump [Re: RoadRunnerJD] #1092900
10/11/11 11:37 PM
10/11/11 11:37 PM
New York
EF8aar Offline
EF8aar  Offline
New York
Some good information here on this recent topic..
https://board.moparts.org/ubbthreads/show...e=7#Post6859223
Re: 340 Water Pump [Re: EF8aar] #1092901
10/12/11 12:59 AM
10/12/11 12:59 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The 1969 factory service manual says on page 7-4, "When replacing the water pump do not install a standard water pump on any air conditioned vehicle or vice versa. See specifications for proper pump."
Specifications for 340:
WATER PUMP IMPELLER
Diameter-Number of Blades
Standard.................4.38"-8
A/C.........................3.50"-6
My one owner '69 340 with A/C has the original 6.5" dia fan pulley. The water pump was replaced several times with after markets, but I now have an NOS 6-blade pump with casting number 2863067, although I'm not 100% sure that is the right casting number for '69 production.
If your original pump has a casting number, it might be original or rebuilt from an original core. If no casting number, it was probably after market cast in Brazil or similar.
You can have your water pump rebuilt with the old impeller. For rebuilders, see Hemmings Motor News. Last time I checked with parts stores like Auto Zone and NAPA a few years ago, they were all selling these water pumps only with the non-A/C impellers.
You should not attempt to use a later year Mopar aluminum water pump, as these are a totally different design with the exit nozzle on the opposite side from the cast iron one.
Re: 340 Water Pump [Re: kentj340] #1092902
10/12/11 09:29 AM
10/12/11 09:29 AM
Warrenton, VA
Warrenton, VA
That's what I thought. Thanks for the input
Re: 340 Water Pump [Re: kentj340] #1092903
10/13/11 05:39 PM
10/13/11 05:39 PM
New York
EF8aar Offline
EF8aar  Offline
New York
WATER PUMP IMPELLER
I just call techincal service for GMB in Jersey. Their listing for a '70 340 is part #120-1070. They do not have a seperate listing for standard vs A/C. 120-1070 has an 8 blade 3.62" (92mm) diameter impeller.
Has anyone here run one of these on a standard (non-ac) car that can provide some feedback?
Thanks!
Re: 340 Water Pump [Re: EF8aar] #1092904
10/17/11 04:12 PM
10/17/11 04:12 PM
New York
EF8aar Offline
EF8aar  Offline
New York
For what it's worth, here is a photo of my original pump along side the new GMB pump... There is a big difference in the impeller diameter, but note the vanes are about the same length. I installed it with a 180 deg. thermostat and the car runs consistanly very cool, just over the first notch of the temperature gauge. The literature with the pump said it had an improved impeller design.
