Re: Brake Rotor Cross Reference for...
[Re: roe]
#1092838
10/11/11 06:31 PM
10/11/11 06:31 PM
Posts: 3,344 Central TX
roe
Central TX
I also found the Raybestos part# 7008R on Amazon for about $120 apiece, but would prefer to go with the Aimco part if they will fit. They seem to be selling off old overstock of discontinued items.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: bordin34]
#1092840
10/11/11 07:00 PM
10/11/11 07:00 PM
roe
Central TX
did you check rock auto?
Yeah, its $140 each for either the Wagner or the Rabestos rotors and $23 for shipping, for a total of about $300. If the ones on ebay will fit, I can get two rotors for $160 plus shipping(appr $30) for a total of about $190. If I can save $110 I'd like to.
roe
[Re: roe]
#1092843
10/15/11 01:56 PM
10/15/11 01:56 PM
roe
Central TX
Well, everything that I could find said that they would fit so I picked them up. We will see. roe
[Re: roe]
#1092844
10/15/11 03:41 PM
10/15/11 03:41 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
roe
The rotor you need is a 3 yr only, 2 piece part, hence the price , dr. diff sells a bearing spacer so you can use the 73 up rotor , if that is what you ended up getting there is your fix ...
[Re: JohnRR]
#1092845
10/15/11 06:25 PM
10/15/11 06:25 PM
roe
Central TX
roe
yeah, thats what I've found so far, and also what was listed on the auction. Im almost 100% sure they'll fit, was just looking for some confirmation from others I guess. I wish I had know about the spacer from Dr Diff, I could have gotten those rotors for like $30-45. At least I know for future reference.
thanks roe
