Re: Auto trans won't back up?
[Re: challenger1320]
#1092812
10/11/11 06:13 PM
10/11/11 06:13 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
If it drives in neutral the rear clutches are locked up.
[Re: DodgeCharger]
#1092815
10/12/11 09:36 AM
10/12/11 09:36 AM
Guitar Jones
How does that happen?
I have also seen the rear clutches welded together from slipping. Using the transmission instead of the brake pedal when going from reverse to drive will eventually wear the rear clutch discs until they start slipping all the time and will then eventually weld themselves together.
[Re: dOc …]
#1092817
10/12/11 01:03 PM
10/12/11 01:03 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I dont know much about automatic trans but on mine the lever that applies the band for reverse broke and I had all gears but no reverse. Mine was on a fresh trans so I dont know if something didnt get put together correctly. The first time I put it in reverse there was resistance with a little pop and then it was just like in neutral when in reverse.
67' charger 499 RB
10.57 at 127
[Re: MRMOPAR]
#1092820
10/13/11 07:20 AM
10/13/11 07:20 AM
Guitar Jones
Low/Reverse band, strut, or servo failure.
If this was the case it shouldn't pull the engine down liked it's locked up. It would just act like high gear. He also never said if it drives in neutral.
[Re: Guitar Jones]
#1092821
10/13/11 10:35 PM
10/13/11 10:35 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
It doesn't drive in neutral.
[Re: DodgeCharger]
#1092822
10/13/11 11:01 PM
10/13/11 11:01 PM
Posts: 16,932 NC
440Jim
NC
If it doesn't creep in neutral, then I think the rear servo, band, or strut. You should be able to see it just by dropping the pan. You should have smooth action pulling on the rear servo by hand and watching the linkage engage the band.
[Re: 440Jim]
#1092823
10/14/11 07:09 AM
10/14/11 07:09 AM
DodgeCharger
Mohnton, Pa
I'm sorry I missunderstood you. It most likely creeps in neutral. On jackstands the tires spin in neutral without the brakes applied. I thought you meant drives the car in neutral. Even when the trans was working ok it would creep if you rev it up in neutral. I was told it was a tight clutch pack and nothing to worry about?
