Auto trans won't back up? #1092809
10/11/11 05:07 PM
10/11/11 05:07 PM
Mohnton, Pa
DodgeCharger Offline OP
Mohnton, Pa
I have a 727 foward manual valve body with low band apply. It was working fine for a few hundred miles.
I parked it and went to back up and the car wouldn't move. All forward gears work fine. I ran the car on jackstands. Forward gears fine. In reverse the tires won't move and it pulls the motor down when I give it slight throttle.
Any Idea what might be the problem? Is it the valve body or something bigger? I am thinking something left loose in the modified valve body causing it to work like a trans brake.
Any ideas would be appreciated.
Thanks,
Re: Auto trans won't back up? [Re: DodgeCharger] #1092810
10/11/11 05:15 PM
10/11/11 05:15 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
the rear clutch plates are welded together
Re: Auto trans won't back up? [Re: dodger mope] #1092811
10/11/11 05:18 PM
10/11/11 05:18 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
I would say it pushed the piston seal out and has the clutch pack locked up
Re: Auto trans won't back up? [Re: challenger1320] #1092812
10/11/11 06:13 PM
10/11/11 06:13 PM
Guitar Jones Offline
If it drives in neutral the rear clutches are locked up.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Auto trans won't back up? [Re: Guitar Jones] #1092813
10/11/11 06:19 PM
10/11/11 06:19 PM
Mohnton, Pa
Mohnton, Pa
How does that happen?
Re: Auto trans won't back up? [Re: DodgeCharger] #1092814
10/12/11 09:24 AM
10/12/11 09:24 AM
Sidney,Ohio
Sidney,Ohio
What I said. Is how it happens
Re: Auto trans won't back up? [Re: DodgeCharger] #1092815
10/12/11 09:36 AM
10/12/11 09:36 AM
I have also seen the rear clutches welded together from slipping. Using the transmission instead of the brake pedal when going from reverse to drive will eventually wear the rear clutch discs until they start slipping all the time and will then eventually weld themselves together.
Re: Auto trans won't back up? [Re: Guitar Jones] #1092816
10/12/11 12:56 PM
10/12/11 12:56 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
PROBABLY the "spring" has flipped-over and locked the clutches up. From what I Have seen .. if the clutches are welded-up due to slippage ... the ATF has been toasted.
Re: Auto trans won't back up? [Re: dOrk !] #1092817
10/12/11 01:03 PM
10/12/11 01:03 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I dont know much about automatic trans but on mine the lever that applies the band for reverse broke and I had all gears but no reverse. Mine was on a fresh trans so I dont know if something didnt get put together correctly. The first time I put it in reverse there was resistance with a little pop and then it was just like in neutral when in reverse.
67' charger 499 RB 10.57 at 127
Re: Auto trans won't back up? [Re: DodgeCharger] #1092818
10/12/11 02:50 PM
10/12/11 02:50 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
In cases where the piston overtravels and pops out of its bore it's usually any one or a combination of things:
Weak Belleville
High Line pressure
No accumulator spring
Re: Auto trans won't back up? [Re: John_Kunkel] #1092819
10/12/11 10:47 PM
10/12/11 10:47 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Low/Reverse band, strut, or servo failure.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: Auto trans won't back up? [Re: MRMOPAR] #1092820
10/13/11 07:20 AM
10/13/11 07:20 AM
If this was the case it shouldn't pull the engine down liked it's locked up. It would just act like high gear. He also never said if it drives in neutral.
Re: Auto trans won't back up? [Re: Guitar Jones] #1092821
10/13/11 10:35 PM
10/13/11 10:35 PM
Mohnton, Pa
Mohnton, Pa
It doesn't drive in neutral.
Re: Auto trans won't back up? [Re: DodgeCharger] #1092822
10/13/11 11:01 PM
10/13/11 11:01 PM
NC
440Jim Offline
440Jim  Offline
NC
If it doesn't creep in neutral, then I think the rear servo, band, or strut. You should be able to see it just by dropping the pan. You should have smooth action pulling on the rear servo by hand and watching the linkage engage the band.
Re: Auto trans won't back up? [Re: 440Jim] #1092823
10/14/11 07:09 AM
10/14/11 07:09 AM
Mohnton, Pa
Mohnton, Pa
I'm sorry I missunderstood you. It most likely creeps in neutral. On jackstands the tires spin in neutral without the brakes applied. I thought you meant drives the car in neutral. Even when the trans was working ok it would creep if you rev it up in neutral. I was told it was a tight clutch pack and nothing to worry about?
