coil over shocks ? #1092424
10/11/11 12:08 AM
10/11/11 12:08 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
How does one determine the pound rating needed for front coil over shock springs ? Small block E body , fiberglass fenders and hood .
Re: coil over shocks ? [Re: rowin4] #1092425
10/11/11 12:12 AM
10/11/11 12:12 AM
Cab_Burge Online work
Cab_Burge  Online Work
Call the shock or spring company that you want to buy them from
Re: coil over shocks ? [Re: rowin4] #1092426
10/11/11 01:15 AM
10/11/11 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to know the front end weight PLUS the length
that the shock should be at for the design length...
(we will say it has a compressed point of 2") so you
have 1800 lbs (front end weight) divided by 2 = 900
divided by 2 (compressed/design length) = 450......
or just call the shock/spring people with your front
end weight
Re: coil over shocks ? [Re: Cab_Burge] #1092427
10/11/11 01:16 AM
10/11/11 01:16 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Gonna be close to #200's But that is a ballpark figure
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
