V6 pushrod Question 87 3.9 vs 89 3.9 #1092177
10/10/11 03:15 PM
10/10/11 03:15 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
I have a 87 dakota with a worn out 89 3.9 (but i used my pushrods from the 87 motor along with the cam and regular lifters when the motor was put in).
My Question is are the pushrods the same? wether it's a 87 non roller 3.9L vs 89 roller 3.9L? I have a rebuilt .60 over 3.9L Short Block assembly with rebuilt heads waiting to get put in, but there are some parts that I have to change over to the new motor, brackets, Carb, intake, ect, ect but I was woundering if I need to use the original 87 pushrods? the new motor also has a flat taplet camshaft
Re: V6 pushrod Question 87 3.9 vs 89 3.9 [Re: 98RAM1500] #1092178
10/10/11 07:38 PM
10/10/11 07:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The lifter will determine the pushrod you need, a roller push rod will not work with a flat tappet, nor will it work the other way.
Stock type pushrods are pretty cheap, spring for a set of new ones.
Don't be the exception.
Re: V6 pushrod Question 87 3.9 vs 89 3.9 [Re: 98RAM1500] #1092179
10/10/11 08:03 PM
10/10/11 08:03 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I was thinking that the 3.9's got roller cams from the get go. Guess not ey?
Re: V6 pushrod Question 87 3.9 vs 89 3.9 [Re: Supercuda] #1092180
10/10/11 08:49 PM
10/10/11 08:49 PM
Crockett ,TX
9
Crockett ,TX
yeah i found a set & measured them and they are alittle shorter on the roller motors, so i will have to use my originals in the motor thats in it right now, yeah the 87 3.9L V6 was the first & last to be Carb and to have flat tappet cam then they went to TBI and Roller cams so i guess my 87 is kinda of rare in a way
heres a pick of the truck just for anyone who wants to look
