Big Block RPM question #1092141
10/10/11 02:36 PM
10/10/11 02:36 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
Not really sure if this is a stupid question or not but I have been wondering. I tried the search function to no avail.
Simple question really. How high of rpm's can a mostly stock 440 be safely brought up to when really getting on it?
1968 block, forged flat top pistons, maybe 9:1 and a "whimpy cam" as Mr Yuck put it.
Scott
1969 Super Bee, 383/4 speed
Re: Big Block RPM question [Re: StukaJU87] #1092142
10/10/11 02:49 PM
10/10/11 02:49 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
hyd. cam or solid ???
hyd. and stock heads you are wasting gas spinning it over 5500 ...
Re: Big Block RPM question [Re: JohnRR] #1092143
10/10/11 02:52 PM
10/10/11 02:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How fast you can spin it boils down to the cam and valve springs. I wouldn't want to spin a stock untouched bottom end over 6k though.
Re: Big Block RPM question [Re: JohnRR] #1092144
10/10/11 02:52 PM
10/10/11 02:52 PM
Northern NJ
Northern NJ
Hyd....thanks.
Scott
Re: Big Block RPM question [Re: StukaJU87] #1092145
10/10/11 03:48 PM
10/10/11 03:48 PM
scratchnfotraction Offline
5500 max and call it good
stock springs will start to float a little past 4900-5000...my stock 440 springs do anyways.
but my SB with comp 901-16 springs spins right up to 6200 and no valve float..but the cam has done nosed over at 5200 rpm
but I had to see if it would float the valves with the heavy roller lifters
so I shift it at a 4900-5000 rpms and call it good,been pretty consistant with it
dial down the redline a tad for engine longevity unless you feel lucky
