e body rear defog hardware question #1091979
10/10/11 10:14 AM
10/10/11 10:14 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
Does anyone have a photo of the correct bolts/hardware for the rear defog for a 70 Challenger? Mine came in a box with my project. It was missing the bracket and nuts and bolts.
Thanks. Joe
65 Barracuda
70 Challenger
Re: e body rear defog hardware question [Re: jrwoodjoe] #1091980
10/10/11 10:54 AM
10/10/11 10:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
all I got
Re: e body rear defog hardware question [Re: gtx6970] #1091981
10/10/11 10:56 AM
10/10/11 10:56 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
done
Re: e body rear defog hardware question [Re: gtx6970] #1091982
10/10/11 11:00 AM
10/10/11 11:00 AM
Tenn.
Tenn.
Thanks Bill. All of that stuff is accounted for. Just not sure what type of bolts it is supposed to have to mount it and if the little bracket requires any special hardware. (I don't see that little bracket in your photos either). I assume it is just hex head bolts with nuts and/or washers to mount it to the car.
Joe
Re: e body rear defog hardware question [Re: jrwoodjoe] #1091983
10/10/11 11:04 AM
10/10/11 11:04 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have a couple complete one's at home I can take pictures of when I get home.
Found these.
Re: e body rear defog hardware question [Re: jrwoodjoe] #1091984
10/10/11 11:08 AM
10/10/11 11:08 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I just used regular sheetmetal screws to attach it to the pkg shelf
the center vent uses a standard 10-24 machine thread pal nuts
Re: e body rear defog hardware question [Re: gtx6970] #1091985
10/10/11 12:28 PM
10/10/11 12:28 PM
Tenn.
Tenn.
Gary, that photo of it in the trunk where you can see the little "S" like bracket and how it attaches is what I'm interested in.
So Bill, are you saying that you simply used sheetmetal screws going from the inside of the trunk through the rear defrost/speaker "Assembly" and into the package tray?
Thanks guys, Joe
