painting steering column parts #1091927
10/10/11 08:22 AM
10/10/11 08:22 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
69 b-body
just to confirm the column bracket (upper right hand corner of the picture) was painted black (semi-gloss i would guess) in all cars and the other column parts in the picture should all be the same color, in this case blue? The inner 2 column tubes (not pictured) where natural?
what about the 2 cover plates that seal the column to the firewall? Mine are black, but am unsure if these were painted originally or later?
Re: painting steering column parts [Re: BTTG] #1091928
10/10/11 08:24 AM
10/10/11 08:24 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
here is the picture
Re: painting steering column parts [Re: BTTG] #1091929
10/10/11 09:14 AM
10/10/11 09:14 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1970 B-body ( 1969 is the exact same way and color btw)
Re: painting steering column parts [Re: gtx6970] #1091930
10/10/11 09:15 AM
10/10/11 09:15 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2
fyi, the inner shift/lockout tube is originally natural with a zinc plated lever( the whole tube and lever is plated in this one)
Re: painting steering column parts [Re: BTTG] #1091931
10/10/11 09:17 AM
10/10/11 09:17 AM
SE Pa.
LimeliteAero Offline
SE Pa.
69 b-body
just to confirm the column bracket (upper right hand corner of the picture) was painted black (semi-gloss i would guess) correct in all cars and the other column parts in the picture should all be the same color, in this case blue? correct, colored to match the interior The inner 2 column tubes (not pictured) where natural? correct
what about the 2 cover plates that seal the column to the firewall? Mine are black, but am unsure if these were painted originally or later? as assumed, should be black
the parts that youll be painting blue should be in suede finish.
Re: painting steering column parts [Re: gtx6970] #1091932
10/10/11 09:18 AM
10/10/11 09:18 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
last one.
The black has decent level of gloss to it, just not super glossy by todays standards
I use a single stage enamel dulled approx 15%( essentially just enough to take the glass look off of it)
