Re: somebody school me on dominator carbs
[Re: earthmover]
#1091883
10/10/11 01:23 AM
10/10/11 01:23 AM
Posts: 43,249 Bend,OR USA
Cab_Burge
Is this a trans brake or no trans brake application? I was told by Holley that the three circuit carbs are for trans brake cars,not for foot brake cars I have both and I had to change the intermediate bleeds on the three circuit carb. to make it work good in my car foot braking it. That was the reason I called Holley tech. to ask for there help on getting that carb to work better on my car, I was suprised when they told me that was the wrong carb .Like all things, if you want to make it work you can AndyF had a swinging deal in the race parts on a Holley ultra Dominator for sale, not sure if it is still available They do work well, I have always pick up ET and MPH when switching from a 4150 carb to a 1050 CFM or bigger Dominator carb.
[Re: earthmover]
#1091886
10/10/11 11:13 PM
10/10/11 11:13 PM
Posts: 12,215 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have always heard and believed that the 3 circuit carbs were for transbrake cars. And my personal experience has been that if you need the 3rd circuit, then there is no suitable substitute for it.
But if you don't need it, then it will cause issues. Not the least of the issues is a 3 circuit's tendency to load the engine up when returning to the pits and when staging.
It would be nice if you could test one or the other sometime. Or you can have one of the pros put you one together. (expensive!)
As a foot braker you will most likely want the 2 circuit.
Master, again and still
[Re: Deepockets]
#1091889
10/11/11 08:36 AM
10/11/11 08:36 AM
Posts: 2,930 A shed in England
Tig
A shed in England
Wow...I always thought the 3 circuit was better for street driving Our's is a 1200cfm, 3 cct from Pro Systems set up for my combo. It had good AFR's as delivered, needed only a little more pump shot when we added a spacer this year. (Took us 'till the end of the season to realise it though ) Sorry to Hi-jack but you learn something every day.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Al_Alguire]
#1091893
10/11/11 03:34 PM
10/11/11 03:34 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Dwayne Porter years ago had a thread about tuning these on the street. I was having "Part Throttle Blue" with my 8896 3 circuit carb too. I ended up drilling the main body Under the metering blocks and tapping the hole counter sinking it and added a common Holley jet. One could use air bleed jets too. Worked slick as snot.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
