meziere water pump trick?? HELP #1091775
10/09/11 11:24 PM
10/09/11 11:24 PM
Oh
His and Her 69's Offline OP
Oh
I have 2 pumps and the motor went bad on the one on my car.
My housing is modified and I want to just change the motor part from 1 pump to the other. I have tried to cut the gasket, tap a putty knife in between, tap on it with a plastic hammer and it won't move or break loose.
I don't want to damage the housing taking it apart so what does anyone do to get them apart??
I assume these are replaceable pumps, correct??
Mine keeps blowing fuses so I believe the pump is tying up or something like that. The wiring is all GOOD with no shorts.
Who do you go thru to get a replacement pump??? or do you send it back to meziere???
Please Help as I need to get this done asap.
Thanks David
Re: meziere water pump trick?? HELP [Re: His and Her 69's] #1091776
10/09/11 11:53 PM
10/09/11 11:53 PM
North Carolina
K
keelsracing Offline
keelsracing  Offline
K
North Carolina
if you have the six(6) bolts removed just take a really big hammer and hit the old "broken" motor with the handle to put the weight of the hammer on a small area of impact and they should pop loose the web site should have the replacment motor install istrutions for you so you know which bolts to remove
AND i got my pump motor for them direct because every one did not stock the 55 gpm pump motor
Re: meziere water pump trick?? HELP [Re: keelsracing] #1091777
10/10/11 01:22 AM
10/10/11 01:22 AM
Oh
Oh
I only seen the 4 allen head bolts that hold it on.
Am I missing 2 somewhere??
There are 4 holding the motor on and 4 that hold the motor housing on, 2 at each end.
I will look on their site and see if I can find anything.
Anyone else??
Thanks David
Re: meziere water pump trick?? HELP [Re: His and Her 69's] #1091778
10/10/11 05:20 AM
10/10/11 05:20 AM
Oh
Oh
bump for the morning crew.
Re: meziere water pump trick?? HELP [Re: His and Her 69's] #1091779
10/10/11 07:21 AM
10/10/11 07:21 AM
North Carolina
K
keelsracing Offline
keelsracing  Offline
K
North Carolina
yes two of them are two of the four that hold the motor to the housing
dont remember witch two but they are 180 degrs from each other
Re: meziere water pump trick?? HELP [Re: His and Her 69's] #1091780
10/10/11 07:28 AM
10/10/11 07:28 AM
Caledonia, Ohio
BigDog68Dart Offline
Caledonia, Ohio
dave. my replacement CSR moyor has been on backorder from Summit for a month and a half. make sure yours is available be for you destory it. big hammer and karate chop should remove the old one!
Re: meziere water pump trick?? HELP [Re: BigDog68Dart] #1091781
10/10/11 07:58 AM
10/10/11 07:58 AM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
Dave as said in couple of post earlier make sure you take the bolts out of the motor. You can buy a replacement motor at Jegs. They have them in stock. I have had to replace 2 on our cars this year. The motor you will get from them will be 35 gpm. You can call Meziere direct and get a heavy duty motor 42 gpm and 1/2" bigger that is a direct bolt in. I was told the 55 gpm motor will not fit in the housing without mods.
Jack
Re: meziere water pump trick?? HELP [Re: Moore & Moore] #1091782
10/10/11 08:43 AM
10/10/11 08:43 AM
tboomer Offline
tboomer  Offline
Jack...How much is the motor from Jegs? I have a Meziere pump here with a bad motor. Meziere wants 125.00 to rebuild it.
Re: meziere water pump trick?? HELP [Re: tboomer] #1091783
10/10/11 09:53 AM
10/10/11 09:53 AM
Columbus Ohio
Columbus Ohio
I paid $210 plus tax for one in July.
Re: meziere water pump trick?? HELP [Re: His and Her 69's] #1091784
10/10/11 10:16 AM
10/10/11 10:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine(SB) has a allen head on the end of the armature....
turn it to see if you can free it up... I had to add
a lube to the water to keep it free... its still running
fine now
Re: meziere water pump trick?? HELP [Re: MR_P_BODY] #1091785
10/11/11 03:02 AM
10/11/11 03:02 AM
Oh
Oh
THANK YOU GUYS FOR THE INFO. I REALLY APPRECIATE IT.
I will check into how freely the motor turns, and then getting it apart, then seeing who has one if I still need one.
I wouldn't have thought 2 of the motor bolts also held it to the housing. I believe it would be the bolts at 12 and 6 position as I think there are recesses in the backside at the 3 and 9 positions.
AGAIN THANKS GUYS.
and Big Dod If all else fails I will do as you say and get the BFH out after it. Ha ha
Thanks David
Re: meziere water pump trick?? HELP//UPDATE [Re: His and Her 69's] #1091786
10/11/11 08:03 AM
10/11/11 08:03 AM
Oh
Oh
I got home this am and decided to mess with the old pump.
I had to take out all 8 allen bolts and it pulled apart.
The ones that go thru the motor also hold the motor/housing together.
I spun the motor with the allen wrench and it spins easier then my other one so I am not sure it's seizing up. I will swap motors and see what happens.
Thanks for the info and I figured I would update this incase someone else has to do theirs.
Have A Good Day Guys,
David
