surge at 50-60mph #1091420
10/09/11 09:28 PM
10/09/11 09:28 PM
Stouffville Ontario
7434 mopars Offline OP
Stouffville Ontario
my 70 challenger 440-6 when warm , has developed a serge when crusing at highway speeds, any suggestions would be appreciated
Re: surge at 50-60mph [Re: 7434 mopars] #1091421
10/09/11 09:34 PM
10/09/11 09:34 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
lean or too much advance(timming)
Re: surge at 50-60mph [Re: 7434 mopars] #1091422
10/09/11 09:41 PM
10/09/11 09:41 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Probably a lean condition. What is your primary jet size?
Or your advance timing at that particular RPM.
Re: surge at 50-60mph [Re: Dave Watt] #1091423
10/09/11 09:46 PM
10/09/11 09:46 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
surging is a lean condition but may i also suggest that gas seems to be getting crappier and crappier and vapor lock may be the culprit
Re: surge at 50-60mph [Re: sixpackgut] #1091424
10/09/11 11:02 PM
10/09/11 11:02 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Try ONE jet-size larger on the center-carb.
Re: surge at 50-60mph [Re: Dave Watt] #1091425
10/09/11 11:12 PM
10/09/11 11:12 PM
run it up to the offending rpm in your driveway & note (& post) the timing & I'm assuming this is high vacuum cruising so vac adv is all in just like when your cruising & unless total is way skewed I'd go up several sizes on pri jets. EDIT Much lesser chance but fyi if the others are good check rotor phasing; disconnect/plug vac adv (which alters phasing) and crank up the initial so the total timing is the same as it was at offending cruising rpm & see if it misses more/less or the same & if it changes holler and right now I would pump up the vac can with a Mityvac to max like it is when cruising w eng off & turn the eng slightly with the fan belt or loosen dist housing & turn it till the magnet is lined up with a tooth & see if the pickup gap is right
