repair cost? #1091413
10/09/11 08:52 PM
10/09/11 08:52 PM
Cincinnati Ohio USA
Moeggenpar Offline OP
Cincinnati Ohio USA
Can someone give a ballpark figure for welding in a new torsion bar crossmember support for a 68'Charger? My neighbor runs a body shop and quoted me $1000.00 to $1200.00 I'm going to remove the seats and carpet myself.Does this sound reasonable for this type of job? Thanks for any info
Re: repair cost? [Re: Moeggenpar] #1091414
10/09/11 09:44 PM
10/09/11 09:44 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Seems like a lot. Is he going to replace the front floor pan too?
Astrobuf
So, are you really a Rocket Scientist?
Re: repair cost? [Re: Moeggenpar] #1091415
10/09/11 10:00 PM
10/09/11 10:00 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I'd say it's a little bit steep. He is probably quoting high to make sure he still makes money even if running into issues along the way.
To do a nice job you are looking a 3 hours to remove the old one, grind off old welds and rust, and clean the entire area. 3 more hours to fit the new one in place, mark where you will drill holes in the crossmember for your rosette welds, drill the holes, reinstall, then weld into place, grind the welds smooth. At $150 per hour shop rate thats $900.
Re: repair cost? [Re: Dave Watt] #1091416
10/10/11 02:46 PM
10/10/11 02:46 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I agree thats a lot on money for the job
logan426
