93 dodge 3500 (dualie) brake bleed question #1091410
10/09/11 08:40 PM
10/09/11 08:40 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Hi guys
i have a 93dodge 3500 daulie diesel that i have to bleed thr rear brakes on. It has abs brakes with a valve on the frame rail with wires and a bleeder on it. Do i bleed the rear wheels then the box or ? or if i get the air out at the wheels do i need to bleed it thier? Also do the drums come off or do i have to pull the axles to change brake shoes?
thanks Gene
Re: 93 dodge 3500 (dualie) brake bleed question [Re: 3wracing] #1091411
10/09/11 11:15 PM
10/09/11 11:15 PM
I dont know ABS but I'm assuming you have to start upstream like regular ones but here's a BTT for you
Re: 93 dodge 3500 (dualie) brake bleed question [Re: 3wracing] #1091412
10/10/11 11:29 AM
10/10/11 11:29 AM
Pa
dcoronet383 Offline
dcoronet383  Offline
Pa
Axles will need to be pulled to get the drums off in order to change the brake shoes. I always bleed the ABS first then the passenger rear, drivers rear, passenger front then drivers front.
