What's up with this A/F reading? #1091342
10/09/11 05:15 PM
10/09/11 05:15 PM
Out West
408strokerdart Offline OP
Out West
I know I don't have any "real" data yet, but why would one side be so far off of the other side? I am reading from the same point on each side of the engine and am getting readings (just idle and intermediate so far) that are 5 whole numbers different from side to side. Any idea where i should start looking? Something obstructed in the carb? Air bleed plugged? Just looking for any thoughts from anyone that has gone thru this.
Re: What's up with this A/F reading? [Re: 408strokerdart] #1091343
10/09/11 05:35 PM
10/09/11 05:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
First make sure the headers are tight
Re: What's up with this A/F reading? [Re: MR_P_BODY] #1091344
10/09/11 05:47 PM
10/09/11 05:47 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
misfiring cylinder
Re: What's up with this A/F reading? [Re: sixpackgut] #1091345
10/09/11 06:18 PM
10/09/11 06:18 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
swap the sensors side to side before doing anything drastic
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What's up with this A/F reading? [Re: bigtimeauto] #1091346
10/09/11 07:45 PM
10/09/11 07:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
Waht intake and carb are you running?
Re: What's up with this A/F reading? [Re: Cab_Burge] #1091347
10/09/11 09:43 PM
10/09/11 09:43 PM
Out West
Out West
Quickfuel 1050 dominator on a 598 casting chapman ported intake.
I kept the sensor with the controller it was calibrated for straight from Racepak. I can swap sides and re-check though.
All valid points to check before tearing into anything. I will hit the exhaust tubes with the infra-red gun to check for mis-fire. Engine sounds to good to be to far out of whack.
Keep the ideas coming though. Thanks.
Re: What's up with this A/F reading? [Re: 408strokerdart] #1091348
10/09/11 11:08 PM
10/09/11 11:08 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
What's it look like going down the track. If it has open headers you'll have a tough time making sense of anything except wot. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: What's up with this A/F reading? [Re: 408strokerdart] #1091349
10/09/11 11:37 PM
10/09/11 11:37 PM
NC
440Jim Offline
440Jim  Offline
NC
Where exactly are your sensors located, and exhaust system configuration?
What are the actual readings?
What fuel are you running? gas, methanol, E85, natural gas (methane), etc.
You said 5 numbers, do you mean 13.0 and 8.0 AFR?
Re: What's up with this A/F reading? [Re: mr2performance] #1091350
10/10/11 06:44 AM
10/10/11 06:44 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
To get a good reading at lower RPMs you need the sensors 10 times the diameter of the pipe from the outlet, thats 35" foward of the outlet if you have 3.5" pipes. You would be amazed how much reversion you can get with big pipes at low speed.
Re: What's up with this A/F reading? [Re: nz383man] #1091351
10/10/11 12:20 PM
10/10/11 12:20 PM
Out West
Out West
Will get some WOT graphs asap. I understand that they are the most important on a drag car. This is on C14 fuel, dynotech merge collectors with the sensors in the top of the collector just past the merge. 4" open collector, about 10-12" past the sensor. Sensors are Racepak/bosch tied to a Sportsman data recorder thru individual O2 controllers.
Readings are 22.X on one side and 17.X on the other side. Bring the RPM up some and they come down to 17.X and 12.X respectively.
