Tire diameter formula with known metric tire size. #1091288
10/09/11 03:31 PM
10/09/11 03:31 PM
Vancouver, WA
MoparMarq Offline OP
Vancouver, WA
Some have posted on tire size swaps while seeking a specific tire diameter. Here's the formula for tire diameter.
Tire size is, of course, listed as "SW/AR-RD", where SW is section width (the width of the tire), AR is aspect ratio (the height of the sidewall of the tire expressed as a percentage of width), and RD is the diameter of the rim the tire is designed to be mounted on. E.G., 235/45-16 is a 235 millimeter wide tire with a sidewall height 45% of the width, designed to be mounted on a 16 inch rim.
Overall tire diameter is as follows:
TD = (SW x AR x 2) / 25.4 + RD
The term in parentheses is the height of both sidewalls and dividing by 25.4 converts the units from millimeters into inches for addition to the rim diameter. E.G., (235 x .45 x 2)/25.4 + 16 gives an overall diameter of the above mentioned tire of 24.3 inches.
Re: Tire diameter formula with known metric tire size. [Re: MoparMarq] #1091289
10/09/11 08:54 PM
10/09/11 08:54 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
That is nice and sorta helpful, but as anyone who has worked in a tire store can tell you, 2 different brands of tire the same size can be different heights.
Re: Tire diameter formula with known metric tire size. [Re: RodStRace] #1091290
10/09/11 08:59 PM
10/09/11 08:59 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
You mean same brand tires can have different heights
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Tire diameter formula with known metric tire size. [Re: deansrr] #1091291
10/09/11 09:24 PM
10/09/11 09:24 PM
BDW Online content
BDW  Online Content
Good info, here's a link to calculate and/or compare.
http://www.discounttiredirect.com/direct/brochure/info/tmpInfoTireMath.jsp
Re: Tire diameter formula with known metric tire size. [Re: RodStRace] #1091292
10/09/11 09:24 PM
10/09/11 09:24 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
And widths. I had a pair of 225/70 Good-years that looked about an inch wider than a 225/70 BFG.
Re: Tire diameter formula with known metric tire size. [Re: 440newport] #1091293
10/10/11 02:56 AM
10/10/11 02:56 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The "section width" (225 235 245 255 etc) is the widest part of the tire when mounted & it is not the tread width.
The reason a BFG VS. Goodyear (225/70/15) will be different dimentionally is the mounted rim is not STANDARDIZED - the BFG may have used 6.0" & the Goodyear 7.0" or vice-versa.
