70 cuda hood tie down wire route #1091164
10/09/11 11:01 AM
10/09/11 11:01 AM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
Does anyone have a picture of the way to run the hood lanyard through the grill to the hood? Are there diffrent lengths? No matter how I run it it appears to be to short. This is for a 70 Cuda.
Thanks Jeff
Re: 70 cuda hood tie down wire route [Re: jml19621] #1091165
10/09/11 11:32 AM
10/09/11 11:32 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
When I did these, I ran them between the grille and the header panel. I didn't have originals to compare lenght so I bought what was advertised as the correct ones.
Lanyards were to short to route any other way
Re: 70 cuda hood tie down wire route [Re: gtx6970] #1091166
10/09/11 12:34 PM
10/09/11 12:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it helps at all?
Re: 70 cuda hood tie down wire route [Re: Alaskan_TA] #1091167
10/09/11 11:22 PM
10/09/11 11:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Re: 70 cuda hood tie down wire route [Re: screamindriver] #1091168
10/09/11 11:24 PM
10/09/11 11:24 PM
Harrisburg, Pa.
Harrisburg, Pa.
And another
Re: 70 cuda hood tie down wire route [Re: screamindriver] #1091169
10/09/11 11:28 PM
10/09/11 11:28 PM
Harrisburg, Pa.
Harrisburg, Pa.
And just for your viewing pleasure an original add with a unique routing through a dedicated hole in the bezels...
