Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091046
02/23/14 06:50 PM
02/23/14 06:50 PM
MO
cdp Offline
cdp  Offline
MO
Thought I'd add to this thread if anyone needs some more details.
A friend of mine just picked up a 55k mile June built 340 Roadrunner. Column shift auto with A/C. Snapped a few pics today of just the engine compartment. Can get more pics any time if needed for anyone interested in details.
Though I do thing the carb has been changed out, it appears mostly untouched.
Chris
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091047
02/23/14 06:51 PM
02/23/14 06:51 PM
MO
cdp Offline
cdp  Offline
MO
another pics..
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091048
02/23/14 06:52 PM
02/23/14 06:52 PM
MO
cdp Offline
cdp  Offline
MO
it was kind of cold out, so I just snapped some basic pics.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091049
02/23/14 08:24 PM
02/23/14 08:24 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
That's great! We need more details on later 71 cars (blue engine). There were a TON of unique details when they went from orange (Windsor plant) to blue (Mound Road plant). Valve covers were different, intake castings looked different, engine paint details varied, air cleaner decal, etc. etc. WE NEED A BUNCH more detail on that one!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091050
02/23/14 09:09 PM
02/23/14 09:09 PM
MO
cdp Offline
cdp  Offline
MO
Scott, give me an idea what you want as far as details. I'll do the best I can given the condition of the car being together and knowing some components are hard to get to. I think the owner is keeping it for his collection, so access is easy.
thanks
Chris
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091051
02/23/14 09:23 PM
02/23/14 09:23 PM
Lee Co. Fla.
5carguy Online content
5carguy  Online Content
Lee Co. Fla.
Hey Chris,how about some random shots all around the engine.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091052
02/26/14 03:16 PM
02/26/14 03:16 PM
MO
cdp Offline
cdp  Offline
MO
not the greatest photographer.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091053
02/26/14 03:18 PM
02/26/14 03:18 PM
MO
cdp Offline
cdp  Offline
MO
another.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091054
02/26/14 03:19 PM
02/26/14 03:19 PM
MO
cdp Offline
cdp  Offline
MO
another
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cdp] #1091055
02/26/14 03:20 PM
02/26/14 03:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Its probably going to require some (very delicate) cleaning to get what Id like to see (paint over spray details, small date codes, bolt head markings and plating colors, distributor clamp and surrounding paint details, etc.) maybe start with some good pics with the air cleaner removed.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091056
02/26/14 03:45 PM
02/26/14 03:45 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I like the rare factory option of acorns in the air cleaner
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091057
07/10/14 07:04 PM
07/10/14 07:04 PM
Lee Co. Fla.
Lee Co. Fla.
I come back to this thread all the time for reference.There's some very good information here and if your into detail,this is it.Anyone have any more info?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091058
07/10/14 07:07 PM
07/10/14 07:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ill be adding some more tid bits soon.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091059
07/10/14 07:30 PM
07/10/14 07:30 PM
Lee Co. Fla.
Lee Co. Fla.
Great,thanks.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091060
07/10/14 08:43 PM
07/10/14 08:43 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I have this thread bookmarked. I should be getting my engine components back from the machinist soon. This info will be invaluable when it comes time for me to put it back together.
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1885337
08/05/15 12:30 AM
08/05/15 12:30 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This thread seems to be for pre-'72 340s, as opposed to another similar one that is '72 up.
I removed my '69 340 vibration dampener recently and found the rubber inlay to be in bad shape. The 273, 318, and 340 all got the same dampener made with a cast iron hub and an outer cast iron circle with a rubber layer between. According to this link,
http://www.hbrepair.com/harmonic_balancer_001.htm
the purpose of a harmonic balancer or vibration dampener is to limit the amount of crankshaft twisting caused by power strokes.
I found 2 vendors that will renew the rubber inlay:
www.damperdoctor.com
www.hbrepair.com
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1885352
08/05/15 12:41 AM
08/05/15 12:41 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's photos of my crank pulley, 3 grooves for a 340 with A/C, same pulley as a 318 with A/C. There are no visible markings or part number anywhere on the pulley.
There were also 2 groove and 1 groove crank pulleys for with power steering and without. 273, 318, and 340 shared the same 1 and 2 groove crank pulleys.
This front groove is cast iron with rubber inlay, and the back 2 are spun from sheet metal.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1907159
09/05/15 10:11 PM
09/05/15 10:11 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Scott,
On a 1971 orange 340... What are the dimensions and head markings for the bolt that holds the idle solenoid to the intake manifold?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1907226
09/06/15 12:12 AM
09/06/15 12:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Jason, it looks like this one, an "L" in a circle with 3 hash marks
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1907255
09/06/15 01:18 AM
09/06/15 01:18 AM
JRepucci Offline
JRepucci  Offline
Thanks Scott.
Does it have the "teeth" on the washer face like the hemi solenoid nuts?
