Re: There`s got to be a better way.......................
[Re: Thumperdart]
#1090444
10/08/11 01:56 PM
10/08/11 01:56 PM
Guitar Jones
Were you using just the metal pan gasket or what?
[Re: Guitar Jones]
#1090446
10/08/11 02:46 PM
10/08/11 02:46 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
We use MOTOSEAL 1 on our intake. Supposed to be resistant to gasoline. It has worked great for us.
[Re: Thumperdart]
#1090447
10/08/11 02:47 PM
10/08/11 02:47 PM
Triple Threat
Renton Washington
We've always used silicone on intake gaskets. FWIW my intake hasn't been off the motor since I put it on 5 years ago.
[Re: Thumperdart]
#1090449
10/08/11 03:38 PM
10/08/11 03:38 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have used The right stuff on the last few and never had an issue.
67' charger 499 RB
10.57 at 127
[Re: Thumperdart]
#1090451
10/08/11 05:00 PM
10/08/11 05:00 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
could it be from a poor fit ?
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1090452
10/08/11 05:26 PM
10/08/11 05:26 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
X2, gaskets/ports not aligned and sucking in oil?
[Re: Thumperdart]
#1090454
10/08/11 05:54 PM
10/08/11 05:54 PM
Posts: 6,295 U.S.
moparniac
U.S.
I spray hi-tach on the intake face of the paper gaskets so they stick to the intake side... always on when I remove intake.
(advanced etc sells it)
Mopar Performance
[Re: moparniac]
#1090455
10/08/11 06:02 PM
10/08/11 06:02 PM
Guitar Jones
I have always used the paper on both sides of the metal gasket, just sprayed with hi tak or something similar so it stays in place.
[Re: Guitar Jones]
#1090456
10/08/11 06:07 PM
10/08/11 06:07 PM
Thumperdart
State of confusion
I`d have to mill it again if I use both gaskets as it doesn`t fit w/both plus the leak appears to be bet. the pan and head side not the intake side. :shruggy
