There`s got to be a better way....................... #1090443
10/08/11 01:51 PM
10/08/11 01:51 PM
State of confusion
Thumperdart Offline OP
State of confusion
Upon tear down of my heap, ALL of intake valves had oil on em and the exhaust were all dry so I assume my intake is leaking and I`ve tried everything I can think of to seal it. Actually I didn`t try the right stuff cos I thaught silicone and fuel were a no no plus it would be a bear to remove the intake for a change or inspection............any suggestions?
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090444
10/08/11 01:56 PM
10/08/11 01:56 PM
Guitar Jones Offline
Were you using just the metal pan gasket or what?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: There`s got to be a better way....................... [Re: Guitar Jones] #1090445
10/08/11 02:31 PM
10/08/11 02:31 PM
State of confusion
State of confusion
I use the paper between the head and valley tray and the intake straight on the tray.
Re: There`s got to be a better way....................... [Re: Guitar Jones] #1090446
10/08/11 02:46 PM
10/08/11 02:46 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We use MOTOSEAL 1 on our intake. Supposed to be resistant to gasoline.
It has worked great for us.
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090447
10/08/11 02:47 PM
10/08/11 02:47 PM
Renton Washington
Triple Threat Offline
Renton Washington
We've always used silicone on intake gaskets.
FWIW my intake hasn't been off the motor since I put it on 5 years ago.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: There`s got to be a better way....................... [Re: Triple Threat] #1090448
10/08/11 03:06 PM
10/08/11 03:06 PM
State of confusion
State of confusion
Thankxxx guys...........
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090449
10/08/11 03:38 PM
10/08/11 03:38 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have used The right stuff on the last few and never had an issue.
67' charger 499 RB 10.57 at 127
Re: There`s got to be a better way....................... [Re: dragram440] #1090450
10/08/11 04:49 PM
10/08/11 04:49 PM
State of confusion
State of confusion
That may be the route I go this time............thankxxx.
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090451
10/08/11 05:00 PM
10/08/11 05:00 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
could it be from a poor fit ?
home of the
Sox and Martin Hemi Duster
Re: There`s got to be a better way....................... [Re: HEMIFRED] #1090452
10/08/11 05:26 PM
10/08/11 05:26 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
X2, gaskets/ports not aligned and sucking in oil?
Re: There`s got to be a better way....................... [Re: HEMIFRED] #1090453
10/08/11 05:30 PM
10/08/11 05:30 PM
State of confusion
State of confusion
I`ve had it milled and the fitment seemed good with and w/out gaskets.
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090454
10/08/11 05:54 PM
10/08/11 05:54 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I spray hi-tach on the intake face of the paper gaskets so they stick to the intake side... always on when I remove intake.
(advanced etc sells it)
Mopar Performance
Re: There`s got to be a better way....................... [Re: moparniac] #1090455
10/08/11 06:02 PM
10/08/11 06:02 PM
I have always used the paper on both sides of the metal gasket, just sprayed with hi tak or something similar so it stays in place.
Re: There`s got to be a better way....................... [Re: Guitar Jones] #1090456
10/08/11 06:07 PM
10/08/11 06:07 PM
State of confusion
State of confusion
I`d have to mill it again if I use both gaskets as it doesn`t fit w/both plus the leak appears to be bet. the pan and head side not the intake side. :shruggy
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090457
10/08/11 06:12 PM
10/08/11 06:12 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
spray the hitack on the paper gasket and stick to the head! then use the metal pan and intake side as normal.
Mopar Performance
Re: There`s got to be a better way....................... [Re: moparniac] #1090458
10/08/11 10:30 PM
10/08/11 10:30 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
dom, if the intake is leaking, the paper should be saturated on the bottom side. look at the int.valve stems to see if oil is seeping past the seals. with all those yrs of street driving and that roller cam the guides might be worn.
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090459
10/08/11 10:39 PM
10/08/11 10:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Pan against the heads, the pan seals the oil. Then put the paper on the intake side
Re: There`s got to be a better way....................... [Re: tjmarcus1] #1090460
10/08/11 11:01 PM
10/08/11 11:01 PM
State of confusion
State of confusion
But then why aren`t the ex. valves oiled? The guides check out ok when George checked em.......
Re: There`s got to be a better way....................... [Re: Bigcube] #1090461
10/08/11 11:05 PM
10/08/11 11:05 PM
State of confusion
State of confusion
So are you saying the metal pan seals better than the paper? Cos if that`s the case then I`ll give it a shot. I`m re-porting the heads now and will be ready for the valve job and final assembly soon so hopefully I can pick up the block from Pettis and get this pig assembled and hit the track. Thankxxx again guys........can`t have oil deluding my 9.78 intake charge.
Re: There`s got to be a better way....................... [Re: Thumperdart] #1090462
10/08/11 11:11 PM
10/08/11 11:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You checked it with a feeler gauge or a bright light yes
Gus
64 Plymouth Savoy
Dana 60
