Cool weather tune up? #1090313
10/08/11 09:39 AM
10/08/11 09:39 AM
tboomer Offline OP
tboomer  Offline OP
Couple of questions here..Last weekend I think I may have been a tad lean..Carb is an 1150 Dominator that is square jetted at 90. I know that you should jet for mph,not et. I don't think I can get out today but it is supposed to be 85*. So the D/A will be pretty much like summer. Next weekend should be much cooler with temps back into the 50s...Is there any way to guess this? There won't be anytime to test in cool air. Also haven't checked the timing yet,but I think Jim had it set at 36* Any ideas appreciated...I need a tenth by next weekend!! Thanks,guys!!
Re: Cool weather tune up? [Re: tboomer] #1090314
10/08/11 09:56 AM
10/08/11 09:56 AM
PA
moparacer Offline
moparacer  Offline
PA
Just throw 2 in the front and 2 in the back for next weekend and let it alone this weekend?
Just depends on what "tad" lean is...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Cool weather tune up? [Re: moparacer] #1090315
10/08/11 10:21 AM
10/08/11 10:21 AM
tboomer Offline OP
tboomer  Offline OP
Just a gut feeling...I think it would be safe to go up to 91s or 92s... We only get two time trials next weekend...If it slows from the last outing,then we can put the 90s back in.
Re: Cool weather tune up? [Re: tboomer] #1090316
10/08/11 10:30 AM
10/08/11 10:30 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Ted what makes you think you are lean?
What did the carb come with from builder/manuf.?
This weekend could be deceiving, the temp is up... But the Barom. is VERY high 30.32"
A weather station is needed to keep track of DA/ ETs.
The only way you can get a .1 sec ET on tuning is if you were WAAAAAAAY off to start with.
More info and good luck, Don
Re: Cool weather tune up? [Re: cudadon] #1090317
10/08/11 11:41 AM
10/08/11 11:41 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Don! I haven't a clue as to what the carb had in it...I don't have a weather station but here is the best mph run from last weekend with the 90s in it
Temperature...62.6
Humidity......16%
Barometer.....30.27
Corrected Alt.1129'
MPH...........103.95
Perhaps I should just leave it alone?
Re: Cool weather tune up? [Re: tboomer] #1090318
10/08/11 01:18 PM
10/08/11 01:18 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Why not run it as is and then jet up on your next run and see what you pick up, or are you restricted on runs.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Cool weather tune up? [Re: tboomer] #1090319
10/08/11 10:35 PM
10/08/11 10:35 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
is it consistant?
or do like mike (deaks) said if it goes faster dial off that run.
if it slows, put the old jets back and dial off that run.
it does look like it will be cooler next week. if the baro. stays high it could be GOOD air.
if your current tune is right the DA won't change enough to need a jet change. IMHO
Don
Re: Cool weather tune up? [Re: cudadon] #1090320
10/09/11 08:46 AM
10/09/11 08:46 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Mick and Don! The car never varied more than .077 from morning till afternoon.
Re: Cool weather tune up? [Re: tboomer] #1090321
10/09/11 09:07 AM
10/09/11 09:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
As a round figure I use 20*... if the temp drops 20*
I do a single jet change but this is dependent if you
were on with the tune up
Re: Cool weather tune up? [Re: MR_P_BODY] #1090322
10/09/11 09:51 AM
10/09/11 09:51 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Mike! I think I will leave it alone and just check the timing!
Re: Cool weather tune up? [Re: tboomer] #1090323
10/09/11 11:40 AM
10/09/11 11:40 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I think you will run better both in the hot & cool sq jetted @ 92 .
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Cool weather tune up? [Re: MRMOPAR622] #1090324
10/09/11 01:34 PM
10/09/11 01:34 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I would use a weather station. Track the DA, temp, jet, etc.
I have a "summer" tune and a "fall" tune...but usually leave it alone,,and dial the car to the weather...this way i know if something is going on with the car,,,if it falls off or picks up,,etc.
Took a few seasons to "figure" it all out...but now i know what the car "should" do.
Even won some $$ at Norwalk with my weather station...going rounds with Jack Moore
Doug
This is the weather station i used to have,,,then upgraded to a TAG,,,lol
Re: Cool weather tune up? [Re: 69CHARGERMD] #1090325
10/09/11 03:34 PM
10/09/11 03:34 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Re: Cool weather tune up? [Re: Labratt] #1090326
10/09/11 04:48 PM
10/09/11 04:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Go get em Ted ! Ron
Re: Cool weather tune up? [Re: 69CHARGERMD] #1090327
10/10/11 09:24 AM
10/10/11 09:24 AM
tboomer Offline OP
tboomer  Offline OP
Doc...I can always count on you for a laugh!! That thar hillbilly weather station is cool...If I ever get one,I want a Kestrel..
Re: Cool weather tune up? [Re: 69CHARGERMD] #1090328
10/10/11 10:33 AM
10/10/11 10:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to have one just like that but I got rid of it..
mine was broke... it never changed at all IN THE
TRAILER so thats when I got the TAG unit
Re: Cool weather tune up? [Re: tboomer] #1090329
10/10/11 11:01 AM
10/10/11 11:01 AM
NC
440Jim Offline
440Jim  Offline
NC
IMO, a Dominator carb is less sensitive to jet changes than most 4150 carbs. So to me, a 2 number jet change is very small. The big question is how close you had it jetted for 85º air (say 2500' DA). Going to 55º air (say 500' DA) I would richen it 4 jet numbers.
And as mentioned, the barometric pressure needs to be considered to really know the DA.
Re: Cool weather tune up? [Re: tboomer] #1090330
10/10/11 11:09 AM
10/10/11 11:09 AM
NC
440Jim Offline
440Jim  Offline
NC
Temperature...62.6
Humidity......16%
Barometer.....30.27
Corrected Alt.1129'
Are those the track conditions (baro, etc)?
Using the online calculator, those numbers are about minus 100 ft DA. If that is the reported aviation baro (corrected to sealevel), your track would have to be at 1000' elevation (like Tri State Raceway) to get 1129 DA (29.19"Hg actual track barometer).
Re: Cool weather tune up? [Re: 440Jim] #1090331
10/10/11 11:15 AM
10/10/11 11:15 AM
tboomer Offline OP
tboomer  Offline OP
Jim...What calculator are you using? I have seen that the tracks elevation is 850'-889'..
Re: Cool weather tune up? [Re: tboomer] #1090332
10/10/11 11:22 AM
10/10/11 11:22 AM
NC
440Jim Offline
440Jim  Offline
NC
850-900 ft elevation sounds about right.
There are a few, but this one has track's listed for elevation and "estimated" conditions for any day. After using their estimate, you can change the numbers to actual track and hit calculate again. The big thing is putting in the correct barometer, some calculators want "aviation" barometer and they correct to track elevation. Others want actual track barometer (most), or you can put in zero track elevation and actual track barometer.
Drag Times calculator
Also:
http://wahiduddin.net/calc/calc_da_rh.htm
And the tons of them at Wallace Raceing:
http://www.wallaceracing.com/adi.php
