Keisler TKO and Mopar's Bellhousing
#1089694
10/06/11 11:16 PM
10/06/11 11:16 PM
Posts: 375 Canada
DmanSRT71
Canada
Is there any reason why the Keisler modified TKO would not bolt to the Mopar bellhousing (lakewood, I believe). ....P5153602
I've searched for the answer, with no luck
thanks Darren
69 Road Runner 383/auto/N96
71 Demon 340/4 spd
Would like to find a rust free Cuda body.
Re: Keisler TKO and Mopar's Bellhousing
[Re: NV69B7RR]
#1089697
10/06/11 11:41 PM
10/06/11 11:41 PM
Posts: 375 Canada
DmanSRT71
Canada
I thought the same as DaytonaTurbo....and No, I haven't asked Keisler. I bought a second hand "new" kit, and it's been tough getting answers from them.
71 Demon 340/4 spd
[Re: NV69B7RR]
#1089698
10/07/11 12:46 AM
10/07/11 12:46 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes My Kiesler modified Lakewood has 2 sets of trans mounting holes, the original ones and the ones Kiesler added to fit the TKO....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: DmanSRT71]
#1089699
10/07/11 01:07 AM
10/07/11 01:07 AM
Posts: 18,157 Mass
DAYCLONA
Mass
thanks Darren
Darren,.. that(P5153602) bellhousing is for 5.7/6.1 applications, and is TKO acceptable directly from Lakewood, has provisions for manual linkage or hyd TOB, or you can use the 1995 Dakota hyd. set up to actuate the clutch...
Misc FYI...Lakewood has a new smblk 273-360 safety bellhousing, TKO only PN#15315
IIRC...B/RB Lakewood bells can still be purchased thru Keisler, or sent to them for TKO modification/application,
Keisler also has a new aluminum smblk 273-360 "factory" style cast bell for the TKO, no need to supply a factory original bell for modification
Mike
[Re: DAYCLONA]
#1089700
10/07/11 09:22 AM
10/07/11 09:22 AM
Posts: 375 Canada
DmanSRT71
Canada
Alright, great. So Lakewood has done what Keisler has been doing to a smallblock bell then. Thanks Mike. Darren Quote:
thanks Darren
Mike
71 Demon 340/4 spd
