tube or not to tube #108939
08/22/08 03:15 PM
08/22/08 03:15 PM
Central Vermont
DUSTERB'D Offline OP
Central Vermont
I just got a set of 28-11.5-15 M/T slicks, these will be on 10" rims, should I run tubes in these or is it not needed. The rims are drilled for screws, so if I use tubes they should be screwed down to keep from shearing off valvestem, right?
Re: tube or not to tube [Re: DUSTERB'D] #108940
08/22/08 03:54 PM
08/22/08 03:54 PM
BRawls Offline
super gas
BRawls  Offline
super gas
You want to screw the tires to the wheel either way. A tube MAY cost you a little ET on a high HP car with large tires (dragster). The tire will lose air over a short period of time without the tube. With the size tire you are running I would run the tube and not worry.
Re: tube or not to tube [Re: BRawls] #108941
08/22/08 08:57 PM
08/22/08 08:57 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
Run tubes! You will thank me instead of finding a flat tire or two once a month.
