Re: Pick my intake! Basic 440 motor [Re: eightlitermopar] #1089200
10/06/11 03:02 PM
10/06/11 03:02 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
Re: Pick my intake! Basic 440 motor [Re: Mr.Yuck] #1089201
10/06/11 04:28 PM
10/06/11 04:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've been using this "crap" gas since it came out and have yet to have a gas related problem.
Then you are the only person in the country with a non fuel injected, recreational use, non 24/7/365 race car that hasn't....
What's your secret ?
Re: Pick my intake! Basic 440 motor [Re: JohnRR] #1089202
10/06/11 05:10 PM
10/06/11 05:10 PM
North Central Florida
E
eightlitermopar Offline OP
E
So far it messed one of my carbs up bad enough I finally pulled it and put it on the shelf for now....
the input has got me thinking though, I would like to boost up the motor, but we are in limbo as far as what to do. We have the small cam mentioned already from a previous motor we got, and the 906 heads are currently on the motor....
I would love to see a set of eddy heads go on the motor, but then again as Mr. Yuck said...it's not like I could just throw heads on it. Then I am looking for a definate heads, headers, camshaft and intake setup so there won't be a gross mismatch....
Hmmm
eight
Mopar or no car
Re: Pick my intake! Basic 440 motor [Re: eightlitermopar] #1089203
10/06/11 08:51 PM
10/06/11 08:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
do this..add the cam t-chain set, headers, intake (CH4B) carb of choice (no 750 eddy's) and run it. See how you like it. Then if you want to upgrade to EFI do it. I think you'll be happy. A small cammed 440 is going to put you back in the seat.
A good cheap build (and I've done a few) is a new t-chain set, summit 488 cam, CH4b intake, holley 750 carb, headers and MP electronic ing. Makes for an easy 13 second b-body. Ran 12.90's w/ the same set-up w/ 3.91's and a 2800 stall. Non-ported 906 heads, cheap headers and 2.5 exhaust.
Re: Pick my intake! Basic 440 motor [Re: Mr.Yuck] #1089204
10/06/11 09:33 PM
10/06/11 09:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
With a mild cam and stock heads, IMO a used CH4B is your best bet if you're using a carb or throttle body injection. Now if you decide to do a big of a cam and a set of better flowing heads, consider an edelbrock victor efi intake and do a port efi system instead. Good, even flow to all cylinders and port efi, this is where you see the real gains over carb as you don't have the wet flow issues like with carb or throttle body efi on a cold start. Also you have minimal cylinder to cylinder a/f variations with a setup like that. Costs a little more, but if modern style turn key driveability and response is what you're after, IMO it's the best choice.
Re: Pick my intake! Basic 440 motor [Re: DaytonaTurbo] #1089205
10/07/11 07:04 AM
10/07/11 07:04 AM
PNW
Danan Offline
Danan  Offline
PNW
1. Think long and hard about what you want the car to do/be when it's done. Be VERY honest with yourself or you won't be happy with it and will throw good money after bad to make it right.
2. Research what it will take to achieve your goal. Researching now will keep you from throwing good money after bad (see a pattern? As Moltke said "A plan is nothing. To plan is everything").
3. Build the car to meet your goal.
4. If your goal is a stock 'cruiser' and you have a cast iron intake, I would suggest using what you have. Why spend the money on a CH-4B which is EXACTLY the same as your stock intake except that it's cast in aluminum? Bear in mind that iron (engine) and aluminum (intake) expand at different rates as they heat up and cool. This differential will cause sealing problems that you will avoid with the iron intake.
5. In my opinion, there is nothing wrong with fuel injection. FOR ME, I'm not interested in injection because I understand carburetors and don't feel that a laptop computer should be required to tune my hot rod. Also, I don't mind taking a wrench to my car now and again to keep it running right. It's my hobby...
Re: Pick my intake! Basic 440 motor [Re: Danan] #1089206
10/07/11 12:10 PM
10/07/11 12:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
How can some of you say the factory iron intake is as good as the Eddy intakes ? The worst Eddy intake made over 25 more hp then the stock intake. I will take the Eddy intake any day over the stock intake unless I ran a class where you cant like Stock Eliminator. Ron
Re: Pick my intake! Basic 440 motor [Re: 383man] #1089207
10/07/11 12:28 PM
10/07/11 12:28 PM
Manitoba, Canada
Manitoba, Canada
Danan, the CH4B is not just an aluminum copy of a stock intake. It does flow noticeably better than the stock intake.
Re: Pick my intake! Basic 440 motor [Re: Danan] #1089208
10/07/11 01:56 PM
10/07/11 01:56 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
From the Mopar Muscle magazine article comparing intakes:
Edelbrock CH4B:
This intake has been out of production for years but retains a loyal following. Once Edelbrock's premier two-plane intake, it also sold through Mopar's Direct Connection program back in the day and is well remembered by old-time Mopar enthusiasts. We borrowed this one from local Mopar bud Harry Gicesare. The CH4B is similar in look and layout to the stock intake, and is a relatively low profile design. The numbers showed a substantial improvement compared to the stocker over most of the range tested, particularly higher up in the range. Interestingly, peak horsepower occurred very high in the rpm range with the CH4B, equaled only by the new Victor. It tended to favor higher rpm performance and was kind of soft at the bottom of the range. The averages were quite good among the other two planes (Weiand Action + and Performer RPM), well ahead of the stocker. No wonder people remember this as a good intake.
Re: Pick my intake! Basic 440 motor [Re: DaytonaTurbo] #1089209
10/07/11 02:07 PM
10/07/11 02:07 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Re: Pick my intake! Basic 440 motor [Re: Mopar_Rich] #1089210
10/08/11 12:06 AM
10/08/11 12:06 AM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Why not a swap meet torquer? My 66 coronet has a stock 1968 30k mile 383 with a new chain and a used 600 edelbrock headers and 2.5 tti exhaust 727 3.23s with tall rear tires.This car has great throttle response and loves the freeway with approx 2000 rpm at a 65 mph cruise,just tap the throttle and easily gain 20 mph for passing,or onramp runs.Anyway the torquer was a $25 dollar swap meet find and the only reason I used it was because I already had it.Actually I cant belive how well this thing runs for what it is,a cheap driver.
Re: Pick my intake! Basic 440 motor [Re: crowbait] #1089211
10/08/11 12:32 AM
10/08/11 12:32 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
Holley Street Dominator and a throttlebody injection system will make a great driver....cold weather, hot weather, higher altitude, lower altitude, whatever. It may cost more up front, but for a street car, it will be an improvement all the way around....
Steve
Re: Pick my intake! Basic 440 motor [Re: Strawdawg] #1089212
10/08/11 12:08 PM
10/08/11 12:08 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
Years ago, I had a 69 GTX. The 440 was stock. When the factory carb. went bad, I had it replaced with the Edelbrock Torquer and a 780 Holley. That was the best performance money I ever spent on that car. It really came alive with that combination.
I don't understand why so many of you are still having problems with ethanol gasoline. When racing season is over, around the end of November, I park my car and add a can of Stabil to it. After that I usually start the car about once a month and let it run for a few minutes. The 750 D.P. has been on the car for over 16 years now, and never any problems. In my mowers and weedeater, I do use non ethanol gas for them.
Re: Pick my intake! Basic 440 motor [Re: Mr. T] #1089213
10/08/11 12:30 PM
10/08/11 12:30 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I have always read and heard the Edelbrock "Performer"- NOT RPM- does not make as good of power as an OEM 4bbl iron intake from the performance era. I have also read that although the Weiand "Action Plus" is a competitor to the Performer- the Action Plus makes more power than a stock intake AND the Performer. The Action Plus is still available new.
Keep old mopars alive.
Re: Pick my intake! Basic 440 motor [Re: 2boltmain] #1089214
10/08/11 04:01 PM
10/08/11 04:01 PM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
I just switched from a performer rpm to a street dominator for clearance reasons...
So if anyone is looking for a performer rpm..
Re: Pick my intake! Basic 440 motor [Re: Osyman] #1089215
10/09/11 01:13 AM
10/09/11 01:13 AM
E
E
Thanks for the replies guys....I have a lot of options to think of here.
I talked with my dad and he thinks he wants go "stocker"-ish at this point and just run it. If he likes it, he'll stay with it. If not, we will go from that baseline.
I think we will spring for a bigger cam though for some added torque, I will have to narrow that down and see...
This means stock heads (as stated), HP manifolds, etc etc.
He does have a gently used DUI ignition he acquired, so he will be using that...
As far as intakes go...hood clearance is a concern...
So stock iron,
Torker
Holly dominator intake,
or something similar may be a consideration. Jury is still out.
However, we do have the iron intake (actually we have several)....
The point is...I am getting a lot of ideas here. Thanks for the input.
Keep it coming!
Eight
Mopar or no car
