Re: Pick my intake! Basic 440 motor
[Re: Mr.Yuck]
#1089201
10/06/11 04:28 PM
10/06/11 04:28 PM
Posts: 74,977 U.S.S.A.
JohnRR
U.S.S.A.
I've been using this "crap" gas since it came out and have yet to have a gas related problem.
Then you are the only person in the country with a non fuel injected, recreational use, non 24/7/365 race car that hasn't....
What's your secret ?
[Re: eightlitermopar]
#1089203
10/06/11 08:51 PM
10/06/11 08:51 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
do this..add the cam t-chain set, headers, intake (CH4B) carb of choice (no 750 eddy's) and run it. See how you like it. Then if you want to upgrade to EFI do it. I think you'll be happy. A small cammed 440 is going to put you back in the seat. A good cheap build (and I've done a few) is a new t-chain set, summit 488 cam, CH4b intake, holley 750 carb, headers and MP electronic ing. Makes for an easy 13 second b-body. Ran 12.90's w/ the same set-up w/ 3.91's and a 2800 stall. Non-ported 906 heads, cheap headers and 2.5 exhaust.
[Re: Mr.Yuck]
#1089204
10/06/11 09:33 PM
10/06/11 09:33 PM
DaytonaTurbo
Manitoba, Canada
With a mild cam and stock heads, IMO a used CH4B is your best bet if you're using a carb or throttle body injection. Now if you decide to do a big of a cam and a set of better flowing heads, consider an edelbrock victor efi intake and do a port efi system instead. Good, even flow to all cylinders and port efi, this is where you see the real gains over carb as you don't have the wet flow issues like with carb or throttle body efi on a cold start. Also you have minimal cylinder to cylinder a/f variations with a setup like that. Costs a little more, but if modern style turn key driveability and response is what you're after, IMO it's the best choice.
[Re: Danan]
#1089208
10/07/11 01:56 PM
10/07/11 01:56 PM
Posts: 1,120 MassHole Central
rtman
MassHole Central
Why spend the money on a CH-4B which is EXACTLY the same as your stock intake except that it's cast in aluminum?
From the Mopar Muscle magazine article comparing intakes: Edelbrock CH4B: This intake has been out of production for years but retains a loyal following. Once Edelbrock's premier two-plane intake, it also sold through Mopar's Direct Connection program back in the day and is well remembered by old-time Mopar enthusiasts. We borrowed this one from local Mopar bud Harry Gicesare. The CH4B is similar in look and layout to the stock intake, and is a relatively low profile design. The numbers showed a substantial improvement compared to the stocker over most of the range tested, particularly higher up in the range. Interestingly, peak horsepower occurred very high in the rpm range with the CH4B, equaled only by the new Victor. It tended to favor higher rpm performance and was kind of soft at the bottom of the range. The averages were quite good among the other two planes (Weiand Action + and Performer RPM), well ahead of the stocker. No wonder people remember this as a good intake.
[Re: crowbait]
#1089211
10/08/11 12:32 AM
10/08/11 12:32 AM
Posts: 183 Eden, Texas
Strawdawg
Eden, Texas
Holley Street Dominator and a throttlebody injection system will make a great driver....cold weather, hot weather, higher altitude, lower altitude, whatever. It may cost more up front, but for a street car, it will be an improvement all the way around....
Steve
[Re: Osyman]
#1089215
10/09/11 01:13 AM
10/09/11 01:13 AM
Posts: 1,630 North Central Florida
eightlitermopar
Thanks for the replies guys....I have a lot of options to think of here.
I talked with my dad and he thinks he wants go "stocker"-ish at this point and just run it. If he likes it, he'll stay with it. If not, we will go from that baseline.
I think we will spring for a bigger cam though for some added torque, I will have to narrow that down and see...
This means stock heads (as stated), HP manifolds, etc etc.
He does have a gently used DUI ignition he acquired, so he will be using that...
As far as intakes go...hood clearance is a concern...
So stock iron, Torker Holly dominator intake, or something similar may be a consideration. Jury is still out.
However, we do have the iron intake (actually we have several)....
The point is...I am getting a lot of ideas here. Thanks for the input.
Keep it coming!
Eight
Mopar or no car
