440 question #108840
08/22/08 10:22 AM
08/22/08 10:22 AM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys, want to build a 440 with a six pack. Staring with bare block and retain cast iron heads....what's the best combo for me? IE...906, 915 heads, what cam, and rotating assemblies? Remember nothing too radical, just want a stout street engine.....Thanks Moparts
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 440 question [Re: MoparJunkie] #108841
08/22/08 10:40 AM
08/22/08 10:40 AM
915 heads with KB pistons(in the CR you want) & .035"-.040" quench(piston to head).
Re: 440 question [Re: MoparJunkie] #108842
08/22/08 10:41 AM
08/22/08 10:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
auto or stick? what gear? for a general all around combo I'd use 10:1 flat tops (if they arte out there) you might have to ge w/ TRW fordged 6 pack pistons. If you have a GOOD set of 915's use them. If you are starting w/ core heads you should check online for used iron heads or just shell out the $$$ for some aluminum heads. That said all the usual goodies like, good electronic ingnition, headers, timing chain-gear set. I'd probably try a split duration cam with a 110 or better centerline. Depending on you gear/trans selection and stall/4 speed you can pick the size that fits best.
Re: 440 question [Re: Mr.Yuck] #108843
08/22/08 12:25 PM
08/22/08 12:25 PM
Gonna go with 4 speed and 3.91 gear.....
Re: 440 question [Re: MoparJunkie] #108844
08/22/08 01:47 PM
08/22/08 01:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd look for somthing in the 5teen-520ish range
Re: 440 question [Re: MoparJunkie] #108845
08/22/08 01:50 PM
08/22/08 01:50 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
We did the 906 heads with our 440. Street and strip and worked awesome with a .472 lift 309 duration. It was lopey but we were able to drive it around and still pull out mid 12's.
Re: 440 question [Re: MoparJunkie] #108846
08/22/08 01:53 PM
08/22/08 01:53 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If you do not have a rotating assembly I would recommend a stroker kit. Your choice on how much you want to spend, but they do not have to cost that much.
No replacement for displacement!
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 440 question [Re: HealthServices] #108847
08/22/08 04:23 PM
08/22/08 04:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Depends on how much HP you want? A stock stroke 6 pack 440 can be made to easily put out 500hp. Check out the tech archives, they give the basic rundown of dyno proven 500hp 440's.
Basic combo would be 10:1 compression, good flowing heads(either ported/big valve stockers or eddy rpm/440source stealth aluminums), cam in the ~240@050 range, headers with a good exhaust system, recurved distributor and a well tuned set of carbs.
Re: 440 question [Re: DaytonaTurbo] #108848
08/22/08 05:22 PM
08/22/08 05:22 PM
I want to get 500 hp.... but look as stock as possible? ie...sleeper. As much as a sleeper as a six pack can be...lol Would like to keep cast heads? If possible don't want to stroke either. Can I get that with bigger flat top pistons and good sized cam with ported and polished heads????? Like I said just don't want to get too radical!
Re: 440 question [Re: MoparJunkie] #108849
08/22/08 07:23 PM
08/22/08 07:23 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
In all honesty, a rebuild with KB flat tops set to 0 deck, anda medium sized hydraulic cam (230ish duration at .050) will make 500hp or very close if it's done by a performance shop. It's not magic, nor expensive. No exotic heads, just a good performance 3 angle valve job, adn excellent machining gets you there.
Re: 440 question [Re: MoparJunkie] #108850
08/22/08 08:22 PM
08/22/08 08:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Good for you. Your asking the right question at the right time. You'll get lots of good info, but some of it might sound conflicting at times. You'll need to sort through it and decide what is best for you, based on budget, performance goal, and streetability. You might identify your performance goal in terms of et and mph, and your idea of "streetability" as the responses you get will be even more on-point.
A flat top piston with 915s and a tight quench distance will perform very vey well, however, I think that combo will push the CR up close to 11:1 and might be difficult to use pump gas. But if you want a big cam with lots of lope, you might be able to get away with it. Others have used the reverse dome KB piston, pump gas, iron head, small cam (224* 0.050") and flirted with 12s with BF Goodrichs and 3.23s. Having well prepared heads is key.
Good Luck
Re: 440 question [Re: BSB67] #108851
08/22/08 08:28 PM
08/22/08 08:28 PM
Tight quench meaning deck the block mill the heads????
Re: 440 question [Re: MoparJunkie] #108852
08/22/08 09:31 PM
08/22/08 09:31 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
sounds like a nice project
subscribed for more info
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: 440 question [Re: 7DRRunner] #108853
08/22/08 09:46 PM
08/22/08 09:46 PM
anyone, anyone......
Re: 440 question [Re: MoparJunkie] #108854
08/22/08 10:19 PM
08/22/08 10:19 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I'm a firm believer in Bob K's Mr. Sixpac cam... Idles like a stone stock engine, runs well into the 12's with gears on bias plies. Ask on the A-12 board
I'm using one in a 383... putting a 6bbl set together for it (slowly) even with the 4bbl it does fine... needs more gear, your 3.91's are that's what I have to install soon.
10:1
915's good valve job!
Shoot for squish!
Bob K's cam
Bobs Super Bee
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 question [Re: R70RUNNER] #108855
08/22/08 10:25 PM
08/22/08 10:25 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
230 @ .050 is NOT going to be very "sleeper-like" 224 maybe pushing the stealth thing
Re: 440 question [Re: R70RUNNER] #108856
08/22/08 10:49 PM
08/22/08 10:49 PM
Be more specific on squish.....decking the block? or milling heads?
Re: 440 question [Re: DaytonaTurbo] #108857
08/22/08 10:50 PM
08/22/08 10:50 PM
So Cal
So Cal
Bigger motor less work to get the power you need. Plus gobs of torque is always great to have. No need for big gear or big convertor either. This makes it easier to cruise on the freeway with 3.23s and a tall tire. 75 -80 mph all day no problem yet still be able to click off a 12 sec or better quarter.
Nothing is more tiresome to drive on the freeway with 3.91s or 4.30s at 4k+ rpm and have people fly by you like you are standing still.
You want a car you can drive to the cruises in comfort.
Re: 440 question [Re: HealthServices] #108858
08/22/08 10:59 PM
08/22/08 10:59 PM
So Cal
So Cal
Weight your options on heads too. Check out how much to do all the work on a iron head before you shell out the money. Porting is not cheap. If it gets anywhere past $600 you may be better off getting a aluminum head like that from 440 source. You will also have less tendency to detonate with aluminum heads. Another plus if you have junk gas where you live.
But on another note if you have the alcohol blended fuel (higher octane) where you live you should take advantage of it and build a high compression motor.
Re: 440 question [Re: MoparJunkie] #108859
08/22/08 11:02 PM
08/22/08 11:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Depends. If you are using 915s, achieving a 0.040" quench will be the combination of piston selection, deck milling and head gasket thickness.
