Re: R3 cylinder wall thickness
[Re: DakFink]
#1088104
10/04/11 12:52 AM
10/04/11 12:52 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Only way to know for sure is to sonic check. FIW my old boosted motor was siamese bore, 9.20" deck, R3 that was 4.250" bore. ![](/ubbthreads/images/graemlins/Twocents.gif) Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#1088105
10/04/11 01:59 AM
10/04/11 01:59 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Mike,
Thanks!! I am talking to ProLine and was really surprised that they don't have the equipment to do sonic-checks.
Wall Thickness and Head Gasket thickness between the cylinders was their Big 2 concerns.
They said they usually stick with a 4.125 bore, but will go out to 4.155 when they have to. But that is all Chevy and Ford small block stuff.
They told me that the Turbos like the big stroke, but not so much the big bore.
They said they could build it BUT wanted to know it was going to live. They don't want to build something that may have reliability issues.
I told them I would ask around and see if anyone knew. If not I'd have it soniced when I get home again.
[Re: DakFink]
#1088106
10/04/11 02:17 AM
10/04/11 02:17 AM
Plumb Wired
Blue Ridge, VA
At 4.250" bore mine was fine in the thrust directions but a little thin in the non thrust, half filled, never any issues. At that large of a bore the problem comes with future rebuilds and the possible need for sleeves. If I were to build another boosted engine I'd start with a tall deck block at around 4.155"-4.185" bore and a 4"-4.125" stroke. My old combo was 4.250" x 3.79" stroke, made it hard to build boost with the 106mm, 1.32, g-trim turbo and the short stroke. Did fine with the 101mm, 1.00, f-trim. ![](/ubbthreads/images/graemlins/Twocents.gif)
RIP Monte Smith
[Re: Get-X]
#1088111
10/04/11 06:21 PM
10/04/11 06:21 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Kenny your block is filled to the bottom of the water pump holes. Sonny's sonic checked the block. There was only one area they were concerned with and like Mike stated with his block it was not a thrust area. If memory surves correctly it was either #1 or #2 on the front and it was a small area. I was told by Tim Davis that filling was unnecessary . I had him fill it anyway.
I would not build any W7-9 engine with a 4.155 bore. I realize with boost it is not so important but, from experience I can tell you bore is king with these heads.
Leon
[Re: Leon441]
#1088112
10/04/11 06:28 PM
10/04/11 06:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leon
I agree... I'm sorry I built mine at 4.125 bore... wish I would have gone 4.185 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Leon441]
#1088114
10/05/11 10:51 AM
10/05/11 10:51 AM
Posts: 945 La Vernia, Texas
Pat7272
La Vernia, Texas
Leon
How about 4.185 in a boosted motor? I dont plan on going any less than that I dont think but dont want to go larger than necessary on my first R3 build.
[Re: DakFink]
#1088118
10/06/11 08:52 AM
10/06/11 08:52 AM
MR_P_BODY
Same topic different aspect.
ProLine hit me up with another question yesterday.
How much material is between the 2 center cylinder exhaust gaskets?
They said that this is a BIG issue with engines that have the middle 2 exhaust valves right next to each other. Also the same reason they stay away from conventional SB Chevies for boost builds as well.
They were concerned that the 2 exhaust valves being next to each other and the Larger bore or even a smaller bore with the head chambers milled too much toward each other on the center cylinders would not leave enough material for the head-gaskets to seal and withstand the Heat and Cylinder pressures.
What heads are you running ![](/ubbthreads/images/graemlins/wave.gif)
[Re: DakFink]
#1088120
10/06/11 11:07 AM
10/06/11 11:07 AM
Plumb Wired
Blue Ridge, VA
Kenny, like I said before my old combo siamese, 4.250" bore, oringed, copper gaskets, 30+ pounds of boost, no problems.
I know ProLine knows their stuff but obviously they aren't familiar with SB Mopars. Have you talked with Ryan Johnson (SDSS)?
RIP Monte Smith
[Re: DakFink]
#1088122
10/06/11 12:14 PM
10/06/11 12:14 PM
MR_P_BODY
I've seen on sprint car engines and drag race engines that have a #6 or #8 coolant line running to the area between the center exhaust ports... I didnt do it, I felt there wasnt a reason to on my engine ![](/ubbthreads/images/graemlins/wave.gif)
