wierd problem #1087806
10/03/11 07:35 PM
10/03/11 07:35 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Friday nite,I was doin my burnout in my 67 barracuda racecar,440,when halfway through it started missing bad ,i pull it up to the line and its missing hard ,like its running on 6 or something.Well ,i back it up ,drive to the pit,pull a couple plugs ,they are fine.Pull a valve cover,and the number one intake pushrod is laying in the hole,looked down to see yhe lifter also out of its bore.came home ,pulled the intake,and number 8 pushrod(intake also) is laying out to.There is no wear at all on anything,the adjusters on the rockers are still tight and where they were set,lifters are not collapseed or worn,pushrods are not bent.no nothing.What could have happened?This has all my friends/experts stumped,any thoughts guys????
thanks craig
Re: wierd problem [Re: CraigS] #1087807
10/03/11 08:03 PM
10/03/11 08:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I would have to believe that there was clearance in the valve train. This is the only way the push rod could come out. If your inspection is accurate, I think the valves hung open. Weak springs,bent stems,tight guides. Was it over revved?
Doug
Re: wierd problem [Re: dvw] #1087808
10/03/11 08:10 PM
10/03/11 08:10 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Over reved
Re: wierd problem [Re: CraigS] #1087809
10/03/11 08:35 PM
10/03/11 08:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Over reved OR you have some lobes going out
Re: wierd problem [Re: MR_P_BODY] #1087810
10/03/11 08:52 PM
10/03/11 08:52 PM
ill
dennismopar73 Offline
ill
on over reved but could be
misadjusted rockers
Re: wierd problem [Re: dennismopar73] #1087811
10/04/11 10:09 PM
10/04/11 10:09 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Well,there was no overrev....4500-5000 rpm max...i have a 6000 chip in the msd,its never seen over that.
no visable wear on the cam lobes or bottom of the lifters ....they are perfect.
My dad thinks the valves may have stuck open,but only two on opposite ends of the engine?
the car had just made a good pass,within a couple hundredths of normal,with good mile per hour.
i am gonna put it back together and run it...i am afraid that the two lifters out of the bores on opposite banks may have sapped all the oil pressure and i did drive it back to the pits,but i never looked at the guage while it was running.
thanks for the thoughts ....Craig
Re: wierd problem [Re: CraigS] #1087812
10/04/11 10:42 PM
10/04/11 10:42 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Just reassembled valvetrain...did not touch the adjusters...the clearance(preload) is same as when i installed these 1 year ago....no wear on cam or lifter,yet the 2 pushrods jumped out of their spots.a buddy has a valvespring pressure tester,we will get those measurements tomorrow.so crazy....Craig
Re: wierd problem [Re: CraigS] #1087813
10/05/11 12:01 AM
10/05/11 12:01 AM
Dude, do yourself (and the engine) a favor and drop the oil pan and check ALL of the rod bearings I have lost lifters due to valve train failure and you always, unless the block has lifter bores that are bushed, loose oil pressure, it only takes around 15 seconds of running with no oil pressure to start removing(pushing it out) the oil from the rods and crankshaft Check everything you can so it doesn't end up hurting you, the motor , the car or all three
Re: wierd problem [Re: CraigS] #1087814
10/05/11 01:39 AM
10/05/11 01:39 AM
Az
Crizila Offline
Crizila  Offline
Az
Only way the pushrods can come out is excessive clearance. If nothing is bent / broken, you didn't over rev it, and the lash was set properly, you had valves hung open or you have weak or broken valve springs. Hung valves would be my guess. Run a leak-down or comp test on those holes. You my be able to see valve marks on the pistons with a light in the spark plug hole also. Did you run it hotter than normal?
Fastest 300
Re: wierd problem [Re: Crizila] #1087815
10/05/11 05:47 PM
10/05/11 05:47 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
You should check that there is no contact between pushrod and head. I slight rob here can make them track off. Hard to believe? but I have had it happen twice on different engines. What heads are you running?
My
Re: wierd problem [Re: Cab_Burge] #1087816
10/05/11 09:59 PM
10/05/11 09:59 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
2X, good advice
Re: wierd problem [Re: emarine01] #1087817
10/05/11 11:49 PM
10/05/11 11:49 PM
Guitar Jones Offline
2X, good advice
with this also. As well as checking to see if the pushrods are rubbing somewhere on the heads.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: wierd problem [Re: Guitar Jones] #1087818
10/07/11 04:15 PM
10/07/11 04:15 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
did the leakdown test ....no bent valves.
no rubbing on heads ,although they were close on initial assembly,but no contact.
i really hate to tear down because its such a bear to work on (big block in abody)
you are right though,no sense in ruining a good bullett from laziness
these valve springs are only 1 year old ,on a hydraulic cam w only 509/528 lift.what a drag
Re: wierd problem [Re: CraigS] #1087819
10/07/11 04:18 PM
10/07/11 04:18 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
oh yea....906 heads...ported and fresh
Re: wierd problem [Re: CraigS] #1087820
10/07/11 04:24 PM
10/07/11 04:24 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
tahts funny,angry,what you said about the loss of oil pressure ,cause thats what i believe also,but all these experts around here say that is not a problem cause the crank oils first before it goes to the lifters.But if there is a huge 1/2 inch hole in the oiling systrm it still drops the pressure to 0 .,right?
Re: wierd problem [Re: CraigS] #1087821
10/07/11 06:25 PM
10/07/11 06:25 PM
It will absolutely drop to zero when the lifters come out on almost all of the late model Mopar V8 My Duster has a BB stroker in it with the 1970-71 Street Hemi and 440 Six Pak 6 quart oil pan(works god ) The motor is moved back a little also I have had other A bodys with BB in them and have remove the oil pans with the motor in the car, it is not a piece of cake but it can be done Start by removing the drag link from the idler arm and steering box and drop one side of the tie rod off of the spindle and slide all of it out of the way and then remove the oil pan, several of the oil pan bolts in the front of the motor under the K member have to be removed with a wrench instead of a socket but it is doable with a little patiences and determination Check every rod bearing and maybe several main bearings
Re: wierd problem [Re: Cab_Burge] #1087822
10/08/11 07:03 PM
10/08/11 07:03 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
i think its easier to pull the engine out
Re: wierd problem [Re: CraigS] #1087823
10/10/11 09:21 PM
10/10/11 09:21 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Well the valve springs are good...checked em ,so there is nothing wrong with anything,but the two pushrods did fall out.I dont know what to do other than put it back together after checking the bearings ,and run it.if it happens again ,I'll have to do something at that point,but for now ,there is nothin wrong with it????????
