coolant flow problem 340 / 4speed
#1087333
10/03/11 01:46 PM
10/03/11 01:46 PM
Posts: 149 New York
EF8aar
New York
Hello everyone... I just recently put my 1970 340 on the road after doing much other work on it, so I'm finally driving it. However, I am having problems with the cooling system and it seems to be coolant flow. The car is all stock, new 180 t-stat, not new 16 lbs. cap. The radiator is a 3 row 26" unit. It's a Chrysler radiator, but I believe it is not an actual 'cuda radiator. The coolant is clear, no debris. While driving it runs great and stays cool for about 5 minutes, then the temp climbs to "H". The new POS heat riser is adjusted to full open position. At rest and while at operating temperature with the radiator cap off, I see no movement of fluid. The top hose is hot, the bottom hose is warm. The heater blows cool air and the heater hoses are cool. Could the system be air bound? I say this because I thought for sure I had flow a few nights ago, but this was with the cap on and I did not verify. But then had to drain down the system to re-seal (change out) the t-stat gasket. Or, could the water pump be shot and only operating intermittently? I checked for water leaks and bearing play at the water pump and it's all good. My first guess was the radiator being plugged and perhaps loosening debris and giving me some flow, but wouldn't I get flow to the heater core regardless? I pulled the heater hoses and blew air through them and through the heater core, they appear to be clear. I'm really stumped. I was thinking of flushing the system, but without flow, there is no point. Before I tear into this tonight (pulling the radiator and water pump, if necessary) I was wondering if anyone had any words of advice. All thoughts would be appreciated. Thank you all in advance. and.....Thank You Moparts!
Re: coolant flow problem 340 / 4speed
[Re: EF8aar]
#1087335
10/03/11 02:01 PM
10/03/11 02:01 PM
RapidRobert
1st thing I'd do is pull the stat/refill it/take it back out for a run. On the heater see if the cables on the heater box are positioned right and that the heater hoses are on the right nipples. When it reads H might borrow an infrared gun & find exact temp or just feel it & see if it's anywhere near "hot" and I have a wacky eng temp sender that erratically reads hot & there was no problem and a new $15 sender from Joesixpack" will (soon) solve that.
[Re: Challenger 1]
#1087336
10/03/11 02:10 PM
10/03/11 02:10 PM
Posts: 149 New York
EF8aar
New York
For what I know, the Motor is a stock 340, nothing fancy or radical. I do not have specs on the cam. The carb is a fairly new Edelbrock 650 AVS. Plastic stock shroud. Fan is a spring thermostatic, sitting 2" from radiator. I tested the fan at operating temp and it pulled paper tight to the radiator. I also tested it placing a magazine against the fan while operating, and it stopped. I feel no difference in the fan resistance from engine off to operating temp. It appears fairly new.
When I thought I had some flow I used a laser thermometer and took the following readings:
top hose 185, bottom hose 125, by-pass 182, heater hose 133/146, top of radiator 199, bot of radiator 105, water pump 152, engine temp sensor location 218... the radiator was fairly consistant in temp from top to bot/side to side
[Re: RapidRobert]
#1087342
10/03/11 05:22 PM
10/03/11 05:22 PM
Posts: 149 New York
EF8aar
New York
The coolant started to steam pretty good and suddenly it overflowed out of the top of the radiator pretty good.
Gushing out like a geyser? or just so so? There's definitely a problem. Holler back when you discover more info
The coolant level pushed out straight up about 6 inches above the top of the radiator neck... was that the system 'burp' I was looking for?
Should I top it off and try again tonight, then check the timimg and fuel delivery as Challenger 1 mentioned above?
[Re: EF8aar]
#1087343
10/03/11 05:25 PM
10/03/11 05:25 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
put a new stat in it.. your new one is bad.....
I am truckless..
[Re: EF8aar]
#1087344
10/03/11 05:31 PM
10/03/11 05:31 PM
RapidRobert
I'm trying not to think the worst (block/head cracked). Lets do this: take off the thermostat housing and the thermostat and fill it with coolant to the neck brim. Take off the fan belt so the water pump is disabled. Have a helper start it and put it in gear/foot on the brake & give it a LITTLE gas to load it and you under the hood see if there's any turbulence in the coolant. With the pump immobile there must (should) be a dead calm, no bubbles and definitely no gushing. Do not let it run for more than several minutes max w no pump, but just for this test & holler back when you can
[Re: RapidRobert]
#1087347
10/03/11 09:57 PM
10/03/11 09:57 PM
Posts: 149 New York
EF8aar
New York
Will a system pressure test suffice, because I won't have competent help till the weekend so I won't be able to do this test, but I will pull the t-stat again and see if it's hung up, or whatever. The strange thing is the other night I thought for sure I had good flow; the top hose was stiff and very warm and I had heat. Satisfied, I shut it down. I did not take it for a ride though. Later on I noticed my Car-Quest gasket with no sealant was slightly damp. I decided to put a new gasket on. After I put the new gasket on I thought I was good to go, but this problem appeared again. I also changed the oil yesterday and did not see anything that would resemble a brown or silvery color. The t-stat is installed correctly, cone up. Thanks to everyone for all the help so far.
[Re: EF8aar]
#1087348
10/03/11 11:18 PM
10/03/11 11:18 PM
RapidRobert
Yeah if you have a rad pressure pump you can pump it up to 15 & see if it holds & even without a helper tomorrow you could pull the stat/housing & do the bubble test & let it idle & you eyeball it (several minutes max). If it has a blown head gasket or block or head crack it'll make the water gush out in short order.
[Re: Paul_Fancsali]
#1087351
10/04/11 09:15 AM
10/04/11 09:15 AM
Posts: 149 New York
EF8aar
New York
What is your anti freeze ratio? should be no more then 40% with a high comp 340. You can add more in the winter but if its warm out keep it to around 10-20 below max.
I checked my anti freeze ratio this am and it appears to be definately more than a 50% coolant mix (it's pretty darn green). I tested it with a cheapo Pestone tester and it pegged the scale on the boil over side. I didn't think to read the freeze side. Could that be my boil over problem, too high a ratio? I am not sure what the fellow I bought the car from did for mixing.
