thanks for the caltracks help #1087040
10/02/11 09:52 PM
10/02/11 09:52 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
went to numidia with the links in the low hole 1/4 turn preload rear shocks (ranchos) on 6 and the front full soft (QA1)
i think the front is coming up too easy and i need to get different rims and taller tires before i drop the front and get less wind up.
after i went to 6 on the shocks it seemed to work good. at rear shocks all soft it would throw the front up, drive out some ,then shake the tires a bit.
i have a local friend here that is great help also so thanks again.
Re: thanks for the caltracks help [Re: dmking] #1087041
10/02/11 10:13 PM
10/02/11 10:13 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well it sounds like your geting somewhere now !
Re: thanks for the caltracks help [Re: VernMotor] #1087042
10/02/11 10:35 PM
10/02/11 10:35 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
yes, now to get the 60ft down.
