vapor lock? #1086920
10/02/11 04:32 PM
10/02/11 04:32 PM
In.
bjg Offline OP
bjg  Offline OP
In.
On my 69 gtx 440 with the vapor seperator installed Have not drove car that much since completed notice after driving it and turn it off it will start up right away but if it sits for a short time does not want to start inless I put on pedal. Hope someone can help.
Re: vapor lock? [Re: bjg] #1086921
10/02/11 06:09 PM
10/02/11 06:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds normal to me.
Re: vapor lock? [Re: bjg] #1086922
10/02/11 07:56 PM
10/02/11 07:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
carter carb?
Coming soon!!!!
Re: vapor lock? [Re: Mr.Yuck] #1086923
10/02/11 08:00 PM
10/02/11 08:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
todays gas; 10-15% alcohol. both my cars do the same thing.
Re: vapor lock? [Re: lewtot184] #1086924
10/02/11 11:02 PM
10/02/11 11:02 PM
next time before you crank it take off the air cleaner & jerk the throttle several times & see if you have several good A/P squirts in the bowl
Re: vapor lock? [Re: Challenger 1] #1086925
10/03/11 07:36 AM
10/03/11 07:36 AM
places
79powerwagon Offline
places
Yup. You need to forget everything you've learned about EFI and learn how to operate a carburated engine. Every one is slightly different, and you need to understand how yours works.
Re: vapor lock? [Re: 79powerwagon] #1086926
10/03/11 10:30 AM
10/03/11 10:30 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this isn't a vapor lock problem. its fuel evaporation in the carb. if the engine runs at 180f and the fuel boils at 130f the fuel will vaporize in the carb. both my cars do it. i know if they sit for a week or so i have to get the squirt bottle out and fill the bowls; or grind or the starter, .
