Re: comp vs cam
[Re: Ian]
#1086609
10/03/11 01:42 AM
10/03/11 01:42 AM
Posts: 43,295 Bend,OR USA
Cab_Burge
I would try the smaller one I have a comp Cams custom ground solid roller cam in my 518 C.I. pum gas motor that is very close to yours. Mine is 260 @ .050 on the intake with .420 lobe lift, 1.65 rockers on both sides and 266 @.050 on the exhaust with .409 lobe lift. The motor pulls real hard to above 7800 RPM according to the VDO Extreme playback tach in the car The last time that motor was on a engine dyno it made peak HP at 7300 and 7400 RPM Good luck
Re: comp vs cam
[Re: Cab_Burge]
#1086610
10/03/11 02:53 AM
10/03/11 02:53 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
thanks mate i have never had a roller before , the cam in it was ft 259/265 109 l/c 600 lift ,all my seats on the indy heads were oval my head man here said they were the worst he has seen lol should have listed to ryan on there valve jobs lol
Re: comp vs cam
[Re: Ian]
#1086616
10/04/11 12:04 PM
10/04/11 12:04 PM
Posts: 16,931 NC
440Jim
NC
hi craig got the engine torn down and givin it a freshin up i have that 270/277 roller 700/650 lift or would it go better with a smaller 260/266 cam with the same lift
I was thinking 266 to let the head flow do the work not more cam. The 11.5 CR really limits the duration I would use. The 260 sounds a little small, but since the lobes are more agressive than the 270 (same lift), I would start with the smaller cam. Better to under cam than over cam, IMO.
Re: comp vs cam
[Re: 440Jim]
#1086617
10/04/11 01:45 PM
10/04/11 01:45 PM
Ian
Victoria, Australia
thanks i will try to get comp 11.9 if i can i will give it a final cc after increasing valve releaf and i will give it a sniff of gas at times.
