Which LA oil pan gasket? #1086289
10/01/11 11:38 AM
10/01/11 11:38 AM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
I need to put an oil pan gasket in my 318 '71 Dart today. Is there a pan gasket for the LA engines that is similar to those in a Magnum 5.2? It'd be great to put a rubber/steel one-peice in there. I bought on for a Magnum but it looks like the front of the oil pans are a little different....
Re: Which LA oil pan gasket? [Re: 300by500] #1086290
10/01/11 05:00 PM
10/01/11 05:00 PM
Central TX
roe Offline
roe  Offline
Central TX
Not a one piece, but I used the one from Autozone, part# 1807. Rubber coated gasket with rubber end seals. Sealed mine right up on my 360. I like it much better than the cork
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Which LA oil pan gasket? [Re: roe] #1086291
10/01/11 11:22 PM
10/01/11 11:22 PM
I'll make a note of that #
