Re: 97 ram trans removal
[Re: JohnRR]
#1086260
10/02/11 01:27 AM
10/02/11 01:27 AM
Posts: 4,244 State of retirement
52savoy
State of retirement
Pull the transfer case off first, you'll need to unbolt the trans mount so you can lower the trans some to get at the top bolts , use a stubby gear wrench to get at them.
Not sure if you have to do this on a 97 but my 2000 I needed to spread the frame some to get the crossmember out , you might be able to hammer on it to get it out but you won't get it back in .
You can make a cheapie frame spreader out of a 2X4. Cut it about a 1/4" longer than the inside truck frame measurement. Put one end in and drive the other end in with a BFH.
[Re: JohnRR]
#1086263
10/02/11 08:08 PM
10/02/11 08:08 PM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
Agreed,,, Having done hundreds of transmissions in Ram trucks - a porta-power was the best tool I ever bought
It's supposed to slide up and then out the back,,, yea good luck with that
[Re: gtx6970]
#1086265
10/03/11 04:05 PM
10/03/11 04:05 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Ya no kidding , I spent 10 months R+Ring transmissions on trucks with hopped up Cummins' there wasn't one that just lifted up and came out. I made a spreader out of a bottle jack and some scrap steel because I was too cheap to buy a porta power for home use , the guy I worked with had one for the shop we worked out of.
[Re: tripleblackcuda]
#1086266
10/03/11 06:45 PM
10/03/11 06:45 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Ok thanks for the advice everyone. I think I should be able to get the thing out, hopefully!
Trans Jack...You need it!
These things are pretty heavy and if you think you're gonna just catch it when it drops like a powerglide, or a 904, you're wrong.
Man I ain't lyin!!! Be safe!
