Re: 1 wire alt. / trunk mounted battery
[Re: a493demon]
#1085842
09/30/11 07:11 PM
09/30/11 07:11 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I had the same problem and went through 3 alts, then realized the it was a bad ground. I had to run a ground strap from alt case to eng block.Good luck Brad
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1085843
09/30/11 07:21 PM
09/30/11 07:21 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Run a ground strap from the alt to the block. You can also run the charge wire from the alt to the battery lug of the starter to shorten up the length of the charging wire.
Chris from New Jersey
