best approach to clean up, rustproof /paint underbody?
#1085713
09/30/11 02:26 PM
09/30/11 02:26 PM
kielbasa
Hi guys....have rear axle, trans removed from my car. I have all winter now to putz on it. Goal is durable, painted underbody (for now, just the rear half of the car). Car is southern car with minimal surface rust (more dirty than anything). Here are 4 preliminary ideas I have as of now. I'd rather not sandblast and deal with grit everywhere.
Do I: wire brush it and wipe it clean - Rust Bullet, then topcoat body color? wire brush, acid wash, rinse with water (not sure i feel like doing this under the car) - Por15, then topcoat body color? wire brush, wipe clean - just epoxy primer, then topcoat body color? Wire brush, wipe clean - Eastwood rust inhibitor, Eastwood rust encapsulator, then topcoat body color?
Garage is unheated, so chances are that I would have to wait until next spring to paint, if there's a product that can be applied in cold, great. What would be some of your suggestions? Thanks!!
Re: best approach to clean up, rustproof /paint underbody?
[Re: Challenger 1]
#1085715
09/30/11 09:30 PM
09/30/11 09:30 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Yes, use a hot water pressure washer that makes STEAM. 300 degrees +. That will soften all the undercoating, and melt and blast away all the grease and goo.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: newem]
#1085720
10/01/11 02:05 PM
10/01/11 02:05 PM
Challenger 1
Cincinnati, Ohio
Ideally if you want to do it once and do it right you should sandblast. Maybe you can use some tarps around the bottom of your car to control the dust from going everywhere in your garage.
You can't media blast a car unless it's totally stripped, it doesn't sound like the OP car is bare. The steam cleaner will do the job as good as it can be done.
