Re: Post your Cam Specs
[Re: SCATPK]
#1085554
09/30/11 01:14 AM
09/30/11 01:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I put a cam in my 416 that I had laying around the shop... the car is my Rampage which will be a street/strip car but built for drag week... specs are 105 lsa installed at 105... 260/262, lift .640/.643... this is a solid roller.... I have a couple other rollers that I can use also but I'm starting with this one
[Re: MR_P_BODY]
#1085555
09/30/11 02:42 AM
09/30/11 02:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Dwayne Porter speced my cam and I could not be happier. Course you know my 63 is a street/strip car. I use a solid flat tapped cam with 264 & 270 @ .050. Lift is .624 and .632 with my Hughes 1.6 rockers. Has a 110 LSA and I have it in with a 106 ICL. I really like it as it has the idle just right for me (just enough rump rump to sound nasty but idle fine) and it makes plenty of power. I know the car will go a bit faster as it ran so bad last time out I was surprised it went 11.0's. Oh its a 493 using a .030 over 440 block and a 440source 4.15 crank. Ron
[Re: SCATPK]
#1085560
09/30/11 09:04 AM
09/30/11 09:04 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Being I am looking to replace the cam in my 528 curious what the specs are of the cams most of you racers are running and cubic inch displacment. I know there are lots of things that determin what cam duration, lift and centerline to use but would like to hear what you are running? And is your car dual purpose race/street or auto/4spd?
My build is similar to yours ; heavy B-body, pump gas compression and Big cubes (572ci) with auto trans and 4.10 gears.
Dwayne built the engine and specced the cam which uses a custom Comp solid roller that specs out with 266/272 @ .050 and 110* Lsa. The valve lift is in the .660 range with 1.5 rockers. Idles fine @ 1000rpm in gear and makes killer torque (720ftlbs peak @ 4400)
Ron
[Re: SCATPK]
#1085561
09/30/11 09:24 AM
09/30/11 09:24 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
.672"/.651" lift, 276/284 @ .050", 112 LSA Street/strip 572" hemi in a 3800# automatic. Cam spec'd by Dwayne Porter...been running it since 2006 and couldn't be happier w/ it.
[Re: SCATPK]
#1085563
09/30/11 04:48 PM
09/30/11 04:48 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Post your Cam Specs
No.
[Re: SCATPK]
#1085565
09/30/11 07:28 PM
09/30/11 07:28 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
i have a 509 purple in my 440+0.055 with stepping up to a solid i will look mid to high 250@050 maybe a little more on exhaust. this will keep rev range,max 6500,right and should give me a bit more power through out the range maybe 25-30hp peak.plus much more than that my heads will kill off,pocket ported stealths i have talked to a lot of people including Dwayne who was very helpfull Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
