Re: Paint Stripper Question
[Re: ahy]
#1085486
09/30/11 12:04 AM
09/30/11 12:04 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I used Aircraft stripper years ago & it was very effective, I tried it again last year & was completely disappointed... Back it the 80's that stuff was mean, brush it on, spray it on didn't matter, some paint would wrinkle immediately & the tougher paint took waiting 15-20 minutes & sometimes two applications.... The stuff I tried on a door last year just sat there, I covered it with plastic & waited an hour, it softened the paint but barely....
The old stuff would leave you bare clean steel quickly. hell I stripped a whole Challenger convertible in about five hours, that included all exterior, door & trunk jambs & the engine compartment....
This new EPA approved stuff after over an hour barely touched the one repaint & didn't touch the original paint.....
[Re: 1_WILD_RT]
#1085488
09/30/11 12:16 AM
09/30/11 12:16 AM
Posts: 20,777 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
![](/ubbthreads/images/graemlins/iagree.gif) The local hardware stores have several brands of stripper and I have tried most of them with less than great results. They won't touch the factory paint at all, but work ok for removing a cheap repaint. For an engine compartment I would be carefull using it because of all the panel joints. If any stripper works its way underneath and doesn't get completely removed it could cause paint adhesion issues. I stripped my engine compartment to bare metal with 3M stripping discs and then hand sanded the tight spots by hand with 80 grit. Not as fast as media blasting, but it was far cheaper since the discs are $7.00 or so at the hardware store.
[Re: Neil]
#1085489
09/30/11 12:22 AM
09/30/11 12:22 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I guess I should have elaborated, when I did the Challenger I used Duct Tape to tape off the areas with seams I was concerned about to keep the stripper out then stripped those areas with a D/A.. But since the new stuff isn't worth wasting time & money on I would just pick up a 8" bondo hog & a box of 80 grit....
