Re: 73 B-body front end rebuild, Torsion Bars
[Re: DaytonaTurbo]
#1085451
09/30/11 12:03 AM
09/30/11 12:03 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
All bolted together, but don't tighten the LCA pivot shaft nut, strut rod nut, or cam bolt nuts until t-bars are in and weight of car is on wheels rather than on jack stands. This prevents twisting of bushings from "jack stand hanging" to "weight on wheels" position.
Also, to get the bar into the hex in the LCA, some folks have to remove the upper control arm bump stop to get the suspension assembly low enough to get the bar in the hex. Depends sometimes on how big a bar it is. My 1.00" bars went in without having to remove the bump stop. Smaller diameter bars, you might have to.
