Indybrock heads?? #1085029
09/29/11 10:53 AM
09/29/11 10:53 AM
South Carolina
K
KRYPTONITE Offline OP
K
South Carolina
Where is the Best place to get indybrock heads????
Has anyone had any luck with these heads, and what intake is the best
THANKS
Re: Indybrock heads?? [Re: KRYPTONITE] #1085030
09/29/11 01:15 PM
09/29/11 01:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had a pair for years, got them from Indy, intakes were 306CFM @ .600, no problems, nice-looking stuff. They're sitting with the rest of my back-up motor. Plans for the car have changed, so I may never use them. The intake for them is a Victor, IIRC. (All that stuff is boxed up at my Guru's shop.)
Re: Indybrock heads?? [Re: KRYPTONITE] #1085031
09/29/11 02:08 PM
09/29/11 02:08 PM
AndyF Offline
AndyF  Offline
I'd start with Hughes and go from there. Ryan at SDSS can help also. Mancini probably has them on hand. Or look in the for sale section of this board.
Re: Indybrock heads?? [Re: KRYPTONITE] #1085032
10/27/11 12:08 PM
10/27/11 12:08 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
If you are looking at building a high horsepower (650+HP) small block you may want to hang tight a few months. Edelbrock will be announcing a new small block Victor head that will blow away anything on the market. Don't bother asking me a lot of technical questions about it...I don't know all the details yet. As far as the Indy Brocks
Kevin
Re: Indybrock heads?? [Re: Hughes] #1085033
10/27/11 10:53 PM
10/27/11 10:53 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Kevin:
Would you be able to answer if standard LA intakes and exhaust manifolds will bolt up?
Thanks for the preview, by the way.
Mo' Farts
Moderated by "tbagger".
