Re: 727 tranny that won't stop seeping. Arrrrrrrrrrrrgh!
[Re: moparjo68]
#1084543
09/28/11 07:16 PM
09/28/11 07:16 PM
Posts: 25,777 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Use the same 150 in. lb. torque for the new style gasket.
[Re: John_Kunkel]
#1084544
09/28/11 07:23 PM
09/28/11 07:23 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
I know you said it was from the pan, but there is a rod in the back of the trans body that the servo arm pivots on, I had a leak there and it took me while to figure it out, as well as the usual suspects, dipstick seal and speedo pinion and kickdown/selector lever O-ring leaks.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: KY Charger]
#1084549
09/29/11 10:35 AM
09/29/11 10:35 AM
Posts: 74,992 U.S.S.A.
JohnRR
U.S.S.A.
If it is chrome sand off the chrome on the lip and use the rubber composite gasket with the gray permatex. I thought my gasket was leaking at one corner and then my little light bulb lite up and noticed it was my dipstick o-ring that was leaking.
What he said , if the pan is chrome sand the chrome off the gasket rail or you'll never get it to stop.
I chased a trans leak on my truck for 2 years , turns out it was the fittings for the cooler line threads into the trans case .
Running your hand on the case is not going to find the leak , clean the trans, run it and then put baby powder on it, you'll find the leak.
[Re: JohnRR]
#1084550
09/30/11 02:01 PM
09/30/11 02:01 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
are you using anything besides the gasket to help seal it? I always use weatherstriping glue to attach gasket to pan and then right stuff on gasket and never have a problems with aftermarket pans
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: moparjo68]
#1084552
09/30/11 02:48 PM
09/30/11 02:48 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Well, what the heck is your secret. Cork didn't work for me.
NO real secret ...other than a dead straight and flat pan rail. AND not OVERtorquing the bolts. CORK has always WERKED furr me ....
I also like the cast alum pan ... those pan-rails are always dead-straight ....
[Re: moparjo68]
#1084554
09/30/11 03:51 PM
09/30/11 03:51 PM
Posts: 4,718 Florida
BDW
I know you think it's the gasket, so did I. Replaced the gasket 3 times. Finally figured out it was leaking from multiple other places....... NSS gasket bad Pivot pin Selector seal
[Re: BDW]
#1084556
10/05/11 08:30 PM
10/05/11 08:30 PM
Posts: 486 Sonoran desert, Arizona, USA
moparjo68
You were sooooo right. It was coming from somewhere other than the pan gasket. It was seeping around the pivot pin. I just didn't want to believe it, 'cause I just spent $450.00 bucks having the tranny rebuilt. I crawled under the car last nite, stayed there for about 30 minutes to look for leaks. And there it was........seeping around the pivot pin. I was relieved to find the leak........then mad as heck that the tranny guy either overlooked or just neglected to replace this 10 cent o ring. Thanks alot Alan Willis, with Willis Transmissions in Owensboro, KY. I appreciate for all the extra work you caused me.
[Re: scratchnfotraction]
#1084558
10/06/11 10:54 AM
10/06/11 10:54 AM
JohnRR
U.S.S.A.
makes you wonder how much other stuff he overlooked,did not R&R and replace parts
Not overlooked but not replaced to increase the bottom line , the trans will live past the warranty period .
jack up the rear of the car , clean the area real good , dry it and smear it with a good RTV...
[Re: moparjo68]
#1084561
10/12/11 11:46 AM
10/12/11 11:46 AM
JohnRR
U.S.S.A.
Has anyone done this?
Why? It's not like you'll be doing it again anytime soon .
