Eagle / RPM / 'Source' cranks - Still SSDB for QC? #1084268
09/28/11 01:17 PM
09/28/11 01:17 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Are Eagle / RPM / 440 Source cranks still basically the SSDB (Same "Stuff", Different Box) for QC these days? Has anyone of these "budget" cranks reigned in their QC enough to be able to buy one and NOT expect to have to drop more $$$ to have it cut .010" right from the start?
EDIT: Let's throw Ohio Crank into this mix, too, since there's a lot of flak about their stuff posted over on SpeedTalk.
Also, are K1 Technology's cranks still legitimately "ready to run" in terms of OOB machining (balancing not withstanding)? Seems like the price difference is close to what you'd pay for one of the above brands + a regrind job. Too bad they never offered a 6-bolt 3.75" RB crank (only an 8-bolt version in that stroke).
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084269
09/28/11 01:29 PM
09/28/11 01:29 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I bought an Eagle from Muscle Motors that was spot on, it has made about 300 passes at 7200 RPM's.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: cgall] #1084270
09/28/11 03:08 PM
09/28/11 03:08 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I think the Eagle stuff is a little better than the others you mentioned.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: sixpakdodge] #1084271
09/28/11 03:52 PM
09/28/11 03:52 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Got an Eagle in mine. I have a few passes on it
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: Irun5snd8th] #1084272
09/28/11 04:41 PM
09/28/11 04:41 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have a Eagle and seems to be ok but dont have that many passes on it yet. It didnt have to get reground or balanced. The eagle rods did need a little bit of work.
67' charger 499 RB 10.57 at 127
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084273
09/28/11 04:46 PM
09/28/11 04:46 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
only problem with our Eagle is that the flange is .150 to thick which caused a hardened pump to be eaten up in the trans...
a 1/4" mid plate will solve this..we did have the PTC converter machined when we didn't have a mid plate..
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: smokinwoody] #1084274
09/28/11 05:07 PM
09/28/11 05:07 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I never had any problems with mine.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: dragram440] #1084275
09/28/11 05:11 PM
09/28/11 05:11 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
You didn't get the crank balanced? You know they don't come balanced, right?
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: PorkyPig] #1084276
09/28/11 05:45 PM
09/28/11 05:45 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
OOOOPS! hard to believe it is still running! No it is balanced. I dont know if It came from eagle balanced or if the place the parts store ordered it from balanced it. There is a eagle balance sheet that came with it and all the weights hand writen in and I paid for balanced. The small end of the rod was to small for the .990 pins.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084277
09/28/11 07:15 PM
09/28/11 07:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i bought an eagle crank years ago. mains & rods had to be cut 10 thou. buy american!!!!!!!!!!!!!!!!!! stay safe, seeya.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084278
09/28/11 07:25 PM
09/28/11 07:25 PM
Delray beach, Florida
P
Performance Only Offline
P
i'll just sit here and
i love that term, "spot on".
machine shop owner and engine builder
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: Performance Only] #1084279
09/28/11 07:29 PM
09/28/11 07:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That really means " one spot was on "
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: pittsburghracer] #1084280
09/28/11 07:51 PM
09/28/11 07:51 PM
BradH Offline OP
BradH  Offline OP
Kind of like "rust free" really means "you get the rust for free", eh?
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084281
09/28/11 09:22 PM
09/28/11 09:22 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Oh boy, just when you thought these threads couldn't get beaten to death any more.
Whatever your here, the varying stories between not having to touch it, to grinding it .010 under should tell you about the consistancy in finish machining quality.
BTW - Although not mentioned in th OP's list, K1 is far better in my book.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: turbobitt] #1084282
09/28/11 11:58 PM
09/28/11 11:58 PM
BradH Offline OP
BradH  Offline OP
You're on Moparts, right?
BTW, I did mention K1 above, but not in the same list as the other "budget" cranks.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084283
09/29/11 02:37 AM
09/29/11 02:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
many years back i bought a Source crank & a Eagle, paid the money & sent them to a Metalurolist to see which was the better quality. his verdict was the Eagle crank would crack before the Source unit as his tests showed the Eagle heat treatment made it more brittle. that was a bit dissappointing as the Eagle looked to be better finished. i'm still using that Source crank 7 years later with 700+ hp.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084284
09/29/11 03:30 AM
09/29/11 03:30 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Have two 440 source stroker engines, a 400 stroked with the 4.15" (500 cid), and a 440 stroked with a 4.25" (505 cid.)
The 400/500" engine is automatic, so I didn't check the hole for the transmission pilot bushing, but on the 4.15" crank it was a hair too tight, but easy to fix, just cleaned it up with the correct drill bit size (I think 15/16"?)
The only other issue I had with both kits was the rod side clearance on the #5/#6 rod journal? Just sanded the sides of the rods a few thousandth and it was fine.
After reading all the complaints, I really checked over the crank when assembling the 505 engine, and I mic'ed every journal which was right on spec. I also checked the indexing on every throw, and it checked out fine too. The actual crank stroke was 4.252", but was the same on each throw.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: BradH] #1084285
09/29/11 08:51 AM
09/29/11 08:51 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Woops, didn't see it the first time I read it.
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC? [Re: turbobitt] #1084286
09/29/11 06:56 PM
09/29/11 06:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
4 years runnin' a Eagle crank in my present smallblock and had to have it ground .010,, mainly because the index was off and some slight taper.
